File:IMU dsPIC 30f4012 LogData Raw.png
Revision as of 13:32, 12 July 2008 by LubinKerhuel (talk | contribs) (IMU_dsPIC_30f4012_LogData_Raw Simulink model: Once this model is compiled, the dsPIC (30f4012) transmit the raw values from the MEMs sensors. Data are sent to Matlab (or labview) through the UART at 115200bps with the Tx Output block. The UART buffer do )
Original file(894 × 773 pixels, file size: 35 KB, MIME type: image/png)
current13:32, 12 July 2008Thumbnail for version as of 13:32, 12 July 2008894 × 773 (35 KB)LubinKerhuel (talk | contribs)IMU_dsPIC_30f4012_LogData_Raw Simulink model: Once this model is compiled, the dsPIC (30f4012) transmit the raw values from the MEMs sensors. Data are sent to Matlab (or labview) through the UART at 115200bps with the Tx Output block. The UART buffer do
