Explorer 16 Board
  • One led (Port A7) :
Set UP
Simulink
PIC
Master block configuration
Open the Master block.
Set up PIC peripheral
Digital Input Configuration
Digital Output Configuration
ADC Configuration
UART
UART Peripheral Configuration
Functions
Blinking Leds
Filtering
>>c2d(tf([6],[1 6]),.005,'tustin');  %(need the Control System Toolbox)
html report with the C code generated can be generated. Go to Simulation ==> Configuration Parameters ==> select Real Time Workshop on the left column and check the option Generate HTML report on the right pannel. The model was compiled with Matlab 2007. dsPIC 33FJ256GP710 24JF128GA010 Matlab Report
Matlab Report Hex file to download to target
Logging and Plottng Datas
Pic side
Computer side
