DsPIC Block/UART Configuration
< DsPIC Block
Revision as of 19:30, 3 May 2015 by LubinKerhuel (Talk | contribs) (LubinKerhuel moved page Block/UART Configuration to DsPIC Block/UART Configuration: Block is a special page, creates many issues)
Jump to: navigation, search
Block UART Configuration
UART Dialog, Tab General
The UART Configuration block set the parameters for the UART. Each UART has one Receive Rx pin and one Transmit pin Tx. The UART parameters are commmon for Rx and Tx of the same UART. The number or UART available depend on the Microcontroller used ( defined in the master block). Following parameters are fixed :
  • 1 stop bit
  • 8 bits data
  • no parity
  • no flow control
UART to be used
Main
Baud (kb/s)
Tx Rx Alternativ
TXEN
Gives following information : UxBRG register value. The real bit rate achieved by the microcontroller and the error in percent between the real bit rate and the requested bit rate. The max Byte/Step is the maximum number of byte that can physically be sent during one diagram time step. If your schematic try to send more data through the UART, somme data will not be sent or the real time constraint will be violated (ie, the time step will be longer than expected).
Tx Interrupt
UART Dialog, Tab Tx
Tx Interrupt take place
The UART peripheral has an internal 4 bytes Transmit buffer. Activating the Tx interrupt virtually extend this buffer to the desired size. The complete buffer size is the sum of the Tx interrupt buffer size plus the UART buffer size (4). The Tx interrupt can take place :
  • When the UART Peripheral Transmit buffer is empty
  • When the UART Peripheral Transmit buffer has one empty space
Tx Interrupt Priority
Tx Interrupt buffer size
Rx Interrupt
UART Dialog, Tab Rx
Rx Interrupt take place
The UART peripheral has an internal 4 bytes Receive buffer. Activating the Rx interrupt virtually extend this buffer to the desired size. The complete buffer size is the sum of the Rx interrupt buffer size plus the UART buffer size (4). The Rx interrupt can take place :
  • When the UART Peripheral Receive buffer is full (contains 4 bytes)
  • When the UART Peripheral Receive buffer is 3/4 full (contains 3 bytes)
  • When the UART Peripheral Receive buffer contain 1 byte (receive 1 byte)
Rx Interrupt Priority
Rx Interrupt buffer size
