DsPIC Block/SPI Input Output
Block SPI Input/Output
SPI Input Output Dialog
n° SPI
SPI used
SPI Input
SPI Output
Special SPI
Allow to disable SPI pin function and to use theses pin as digital input/output. The choices are :
  • Always Enable
  • Disable After block execution
  • Re-Enable before block execution
  • Re-Enable Execute and disable
Data Length
block execution of other blocks while no data are received
