DsPIC Block/SPI Configuration
< DsPIC Block
Revision as of 22:44, 26 May 2008 by LubinKerhuel (talk | contribs) (New page: The configuration block set the SPI parameters. =Dialog Box Parameters= ==n° SPI== SPI used ==Mode== Master or Slave : define who is driving the clock signal ==Prescaler== Choose the ...)
n° SPI
SPI used
Mode
Prescaler
SDO Enable
Data length
Slave Select Pin Enable
Sample phase
Clock Active State
Output change on transition
