DsPIC Block/PWM Motor Output
Block PWM Motor Output
Main Dialog Box Parameters
PWM Motor Output main Dialog
PWM Motor Output Dead Time Dialog. some dsPIC has only one Dead Time Prescaler. This Dialog may be different, depending on the dsPIC being used
General Input Enable
Input Periode
Output Channel
Periode
ValMax Periode Calcule
Centered
Edge-Aligned PWM vs Center-Aligned PWM. Center-Aligned PWM multiply by two the max Period and Duty Cycle achievable
Gives information :
Dead Time TAB
PWM motor Dead Time
Dead Time A - B
Dead Time Info
Dead Time PWMx Active
Dead Time PWMx Inactive
