DsPIC Block/PWM Motor Output
< DsPIC Block
Revision as of 20:41, 26 May 2008 by LubinKerhuel (talk | contribs) (New page: The PWM Motor block allows to generate either simple PWM pulse like OC block or PWM pulse with two channel in opposit phase for motor control. This block do not use a timer like the OC or ...)
General Input Enable
Input Periode
Output Channel
Periode
ValMax Periode Calcule
Centered
I Really do not remember what was that for !
Activate the Complementary output of each channel
Gives information :
