DsPIC Block/Output Compare HW
< DsPIC Block
Revision as of 15:43, 1 March 2009 by LubinKerhuel (talk | contribs) (New page: thumb|rght|Block Output Compare Output driver for PWM output data =Outline= [[Image:Block_OutputCompare_DialogBox_HW.png|thumb|right|450px|Output Co...)
Outline
Output Compare Dialog
  • Time Up and Time Down
  • Time Up ane Periode
  • Time Down and Periode
With
Interrupt Priority
Output Channels
Channels Input Type
Max/Channels
