DsPIC Block/Output Compare
Outline
- Time Up and Time Down
- Time Up and Period
- Time Down and Period
Up or Down or Period = <tex>T_{set} * \frac{OCkmax}{MaxChannel}</tex>
With
Interrupt Priority
Output Channels
Channels Input Type
Max/Channels
