DsPIC Block/Output Compare
Block Output Compare
Outline
  • Time Up and Time Down
  • Time Up ane Periode
  • Time Down and Periode
With
Output Compare Dialog
Interrupt Priority
Output Channels
Channels Input Type
Max/Channels
