Please support 32MX320F128H
resodad
Postby resodad » Thu Mar 08, 2012 9:51 pm
Digilent has released the Cerebot MX3 cK board.
I would like to use it because It is small and cheap.
Please consider supporting the 32MX320F128H chip in your next blockset release.
Regards,
resodad
Re: Please support 32MX320F128H
Postby resodad » Thu Mar 15, 2012 5:13 pm
Until you get around to it,
How would I modify the code generated for one chip to work on a different chip?
Postby LubinKerhuel » Mon Mar 26, 2012 12:09 am
Hello John,
32MX320 & 32MX340 chips are now added in latest version (3.7d).
Modifying generated code is pretty easy through MPLAB as the MPLAB 8 or MPLAB X project are created with the source code.
However, that might be quite complicated if chip is too different from an existing chip.
Adding new chip into the blockset is not currently supported.
resodad
Postby resodad » Mon Mar 26, 2012 12:21 pm
Thanks Lubin.
Return to “Request for new functions / Peripheral / Chip support”
Users browsing this forum: No registered users and 0 guests
