how to remove "the Embedded Target for dsPIC"
northbear
Post by northbear » Tue Jul 17, 2007 9:36 am
how to remove "the Embedded Target for Microchip dsPIC" from MATLAB ?
Post by LubinKerhuel » Sat Jul 21, 2007 10:27 am
Delete the directory containing the toolbox and remove the 3 entry added in the matlab path ( File -> set path...)
Simon_says
Re: how to remove "the Embedded Target for dsPIC"
Post by Simon_says » Wed Dec 03, 2008 7:23 pm
I need some more help on this. I can´t find the directory of the Embedded Target for dsPIC blockset. Besides, does this has to be done from matlab or windows environment? I do not want to make mistakes... Please give me a more detailed instuctions please!
Simon_says
Post by LubinKerhuel » Thu Dec 04, 2008 1:35 am
Hello Simon_Say,
I would need more info to help.
do you want to
- remove definitly the blockset
- update the blockset version
The directory can be deleted from either windows or matlab. It is not very important to delete the three directory entry in the matlab path. If files are already deleted, Matlab will not find any files.
Look on your hardrive for a directory called 'blocks' or a file called 'dsPIC_ADC.tlc' to find where the blockset was installed.
Simon_says
Post by Simon_says » Fri Dec 05, 2008 2:16 am
Good!
It is done! Thanks a lot!
Users browsing this forum: No registered users and 73 guests
