wont install
wont install
i have matlab 2008b
Creating dspic\pic32_select_callback_handler.p
Creating examples\CompileAllModels.m
Creating examples\Data_Login_Matlab.mdl
Creating examples\FlexBoard_Blinking_Led.mdl
Creating examples\Servo_ADC.mdl
Creating examples\Servo_Sinus.mdl
Creating examples\dsPIC_33f_Explorer16.mdl
Update path...
ERROR OCCURED
during installation
Undefined function or variable 'dsPIC_Compile'.
No error in the installation I/O process.
errorcode is 98
This script is under development and your assistance is
urgently welcome. Please inform the distributor of the
toolbox, where the error occured and send us the error
report and the informations about the toolbox (distributor,
name etc.). For your convenience, this information has been
recorded in:
C:\Users\paul\Desktop\install.log
Paul
Update path...
ERROR OCCURED
during installation
errorcode is 98
recorded in:
Paul
Re: wont install
Do not install inside the matlab directory.
is it a 32 bit of 64 bit matlab ?
Re: wont install
I'm interrested in your Matlab Toolbox to target dspic.
I have downloaded the trial version limited to 6 I/O.
I have exactly the same problem. I use Matlab R2008a
When I run the install function, here is the result :
INSTALLATION RTWdsPIC
Reading the archiv
Checksum test passed (A9482ECA25A6)
RTWdsPIC version none
RTWdsPIC time stamp 12-Mar-2009 00:30:59
Importing the archiv 100% |******************************|
Toolbox folder is C:\Users\thierry\Documents\dspic R2008a
Creating Readme.html
Creating blocks\EmptySFunction.mexw32
Creating blocks\EmptySFunction.tlc
Creating blocks\GetDsPICParam.p
Creating blocks\RS232_analyzBloc.p
Creating blocks\Set_DialogBoxMask.p
Creating blocks\combinatoire.p
Creating blocks\dsPIC_ADC.mexw32
Creating blocks\dsPIC_ADC.tlc
Creating blocks\dsPIC_ADC_callback.p
Creating blocks\dsPIC_ADC_callback_InitMask.p
Creating blocks\dsPIC_ADC_param2mex.p
Creating blocks\dsPIC_CAN_Config.mexw32
Creating blocks\dsPIC_CAN_Config.tlc
Creating blocks\dsPIC_CAN_Config_callback.p
Creating blocks\dsPIC_CAN_Receive.mexw32
Creating blocks\dsPIC_CAN_Receive.tlc
Creating blocks\dsPIC_CAN_Receive_callback.p
Creating blocks\dsPIC_CAN_Transmit.mexw32
Creating blocks\dsPIC_CAN_Transmit.tlc
Creating blocks\dsPIC_CAN_Transmit_callback.p
Creating blocks\dsPIC_C_function_Call.mexw32
Creating blocks\dsPIC_C_function_Call.tlc
Creating blocks\dsPIC_C_function_Call_callback.p
Creating blocks\dsPIC_CalculusTimeStep.mexw32
Creating blocks\dsPIC_CalculusTimeStep.tlc
Creating blocks\dsPIC_CalculusTimeStep_initMask.p
Creating blocks\dsPIC_CheckParamSimulation.p
Creating blocks\dsPIC_Chronograph.mexw32
Creating blocks\dsPIC_Chronograph.tlc
Creating blocks\dsPIC_Chronograph_Callback.p
Creating blocks\dsPIC_Compile.p
Creating blocks\dsPIC_ConfigClock32f.p
Creating blocks\dsPIC_ConfigClock33f.p
Creating blocks\dsPIC_ConfigRTWOption.p
Creating blocks\dsPIC_ConfigureModelFordsPICTarget.p
Creating blocks\dsPIC_Digital_Input.mexw32
Creating blocks\dsPIC_Digital_Input.tlc
Creating blocks\dsPIC_Digital_Input_callback.p
Creating blocks\dsPIC_Digital_OutputRead.mexw32
Creating blocks\dsPIC_Digital_OutputRead.tlc
Creating blocks\dsPIC_Digital_OutputRead_callback.p
Creating blocks\dsPIC_Digital_OutputWrite.mexw32
Creating blocks\dsPIC_Digital_OutputWrite.tlc
Creating blocks\dsPIC_Digital_OutputWrite_callback.p
Creating blocks\dsPIC_EXT_INT_PWM_callback_InitMask.p
Creating blocks\dsPIC_EXT_INT_PWM_param2mex.p
Creating blocks\dsPIC_Ext_Interrupt_PWM.mexw32
Creating blocks\dsPIC_Ext_Interrupt_PWM.tlc
Creating blocks\dsPIC_Get_Dialog_PopUp_Param.p
Creating blocks\dsPIC_Get_Dialog_PromptString.p
Creating blocks\dsPIC_I2C_Master.mexw32
Creating blocks\dsPIC_I2C_Master.tlc
Creating blocks\dsPIC_I2C_Master_callback.p
Creating blocks\dsPIC_MASTER.mexw32
Creating blocks\dsPIC_MASTER.tlc
Creating blocks\dsPIC_MASTER_callback.p
Creating blocks\dsPIC_MASTER_callback_InitMask.p
Creating blocks\dsPIC_Nop.mexw32
Creating blocks\dsPIC_Nop.tlc
Creating blocks\dsPIC_PIN_Mapping.mexw32
Creating blocks\dsPIC_PIN_Mapping.tlc
Creating blocks\dsPIC_PIN_Mapping_Callback.p
Creating blocks\dsPIC_PWM_CN.mexw32
Creating blocks\dsPIC_PWM_CN.tlc
Creating blocks\dsPIC_PWM_CN_CheckDiag.p
Creating blocks\dsPIC_PWM_CN_callback.p
Creating blocks\dsPIC_PWM_IC.mexw32
Creating blocks\dsPIC_PWM_IC.tlc
Creating blocks\dsPIC_PWM_IC_CheckDiag.p
Creating blocks\dsPIC_PWM_IC_callback.p
Creating blocks\dsPIC_PWM_Motor_callback.p
Creating blocks\dsPIC_PWM_OC.mexw32
Creating blocks\dsPIC_PWM_OC.tlc
Creating blocks\dsPIC_PWM_OC_CheckDiag.p
Creating blocks\dsPIC_PWM_OC_HW.mexw32
Creating blocks\dsPIC_PWM_OC_HW.tlc
Creating blocks\dsPIC_PWM_OC_HW_CheckDiag.p
Creating blocks\dsPIC_PWM_OC_HW_callback.p
Creating blocks\dsPIC_PWM_OC_HW_callback_InitMask.p
Creating blocks\dsPIC_PWM_OC_callback.p
Creating blocks\dsPIC_PWM_OC_callback_InitMask.p
Creating blocks\dsPIC_PWM_motor.mexw32
Creating blocks\dsPIC_PWM_motor.tlc
Creating blocks\dsPIC_PWM_motor_callback_InitMask.p
Creating blocks\dsPIC_PortSetting.p
Creating blocks\dsPIC_Reset.mexw32
Creating blocks\dsPIC_Reset.tlc
Creating blocks\dsPIC_SPI_IO.mexw32
Creating blocks\dsPIC_SPI_IO.tlc
Creating blocks\dsPIC_SPI_IO_Interrupt.mexw32
Creating blocks\dsPIC_SPI_IO_Interrupt.tlc
Creating blocks\dsPIC_SPI_IO_Interrupt_Callback.p
Creating blocks\dsPIC_SPI_IO_callback.p
Creating blocks\dsPIC_SPI_IO_param2mex.p
Creating blocks\dsPIC_SPI_config.mexw32
Creating blocks\dsPIC_SPI_config.tlc
Creating blocks\dsPIC_SPI_config_callback.p
Creating blocks\dsPIC_SPI_config_param2mex.p
Creating blocks\dsPIC_Set_Dialog_PopUp_Param.p
Creating blocks\dsPIC_Set_Dialog_PromptString.p
Creating blocks\dsPIC_TimerSetting.p
Creating blocks\dsPIC_TimerSetting2.p
Creating blocks\dsPIC_UART_RX.mexw32
Creating blocks\dsPIC_UART_RX.tlc
Creating blocks\dsPIC_UART_RX_callback.p
Creating blocks\dsPIC_UART_RX_param2mex.p
Creating blocks\dsPIC_UART_TX.mexw32
Creating blocks\dsPIC_UART_TX.tlc
Creating blocks\dsPIC_UART_TX_Labview_Matlab.mexw32
Creating blocks\dsPIC_UART_TX_Labview_Matlab.tlc
Creating blocks\dsPIC_UART_TX_Labview_Matlab_callback.p
Creating blocks\dsPIC_UART_TX_callback.p
Creating blocks\dsPIC_UART_callback_InitMask.p
Creating blocks\dsPIC_UART_config.mexw32
Creating blocks\dsPIC_UART_config.tlc
Creating blocks\dsPIC_UART_config_callback.p
Creating blocks\dsPIC_code_template.cgt
Creating blocks\dsPIC_main.tlc
Creating blocks\dsPIC_mrmain.tlc
Creating blocks\dsPIC_srmain.tlc
Creating blocks\dsPICdrivers.mdl
Creating blocks\dspicListe.mat
Creating blocks\fOrderingInOut.p
Creating blocks\fPin.p
Creating blocks\fPortRef.p
Creating blocks\pad.p
Creating blocks\padr.p
Creating blocks\rs232gui.fig
Creating blocks\rs232gui.p
Creating blocks\slblocks.m
Creating dspic\Contents.m
Creating dspic\Contents.p
Creating dspic\Contents.txt
Creating dspic\dspic.tlc
Creating dspic\dspic_pic30_gcc.tmf
Creating dspic\dspic_select_callback_handler.p
Creating dspic\info.xml
Creating dspic\pic32.tlc
Creating dspic\pic32_gcc.tmf
Update path...
ERROR OCCURED
during installation
errorcode is 98
recorded in:
C:\Users\thierry\Documents\dspic R2008a\install.log
Provide a brief description of what you were doing when
this problem occurred.
E-mail or FAX this information to us at:
E-mail: marwan@agnld.uni-potsdam.de
Fax: ++49 +331 977 1142
Thank you for your assistance.
And I cannot resolve the problem myself.
Thank you.
Thierry
Reading the archiv
Update path...
ERROR OCCURED
during installation
errorcode is 98
recorded in:
Thank you.
Thierry
Re: wont install
Ok,
This bug should be corrected in the next version. Despite this error, the blockset should be properly installed on your system and should works.
Re: wont install
Thank you for the rapid answer.
But in the simulink libraries, I cannot find the ones that should have been installed !!!
If rightly installed, where should I find theses libraries and what should be the exact names ?
Thank you Lubin.
thierry.
Thank you Lubin.
thierry.
Re: wont install
If files are unpacked in the directory RTWdsPIC :
add to the matlab path directories :
- RTWdsPIC
- RTWdsPIC/blocks
- RTWdsPIC/dspic
dsPIC library should be seen in the simulink library with all others...
I'll try to release the new version soon. (few others bugs to correct before)
- RTWdsPIC
- RTWdsPIC/blocks
- RTWdsPIC/dspic
Re: wont install
I uploaded the corrected version. Just try it (version 0.99d) and let me know...
Users browsing this forum: No registered users and 68 guests
