Can't run examples
fram_22
Can't run examples
Post by fram_22 » Tue Dec 11, 2012 2:31 am
Hello:
I have just download and installed the dsPIC blockset. It was installed properly and it is not included on the matlab directory.
I checked that the matlab folder is set to the dspic blocks folder.
I am using matlab R2010a on windows 7 64bit.
However when I try to compile the examples the following error appears:
File I/O error on file 'dspic.tlc'
Operation that caused an error: open
I am kind of lost here. If someone could explain what does this means and how to workaround that error I would be most thankful.
thank
AbuSaleh
Re: Can't run examples
Post by AbuSaleh » Sun Dec 30, 2012 1:10 pm
I had the same problem and I finally solved it. The solution is to copy the blockset m-file to any place other than C: partition. I have copied it to partition E: and chancged the path of Matlab to this location and run the "install_dsPIC_R2012a.m" file inside matlab. Then open the examples folder and run any example and it will work.
Ahmed
fram_22
Post by fram_22 » Wed Feb 06, 2013 6:57 pm
Thanks for the reply.
It has worked!
Please forgive me for taking so long to answer. I was distracted by some issues at work.
Users browsing this forum: Google [Bot] and 1 guest
