I have just baught a new laptop with windows XP installed. I installed MATLAB R2007B, as well as MPLAB 8.10 and microchip C30 students version. Then I tried to install the block sets into simulink by finding the directory which contains install _dsPIC_R2007b. I excuted it. Then the installation process took place. But when i checked the blocksets into simulink i did not find them. I tried the process many times but without success. Have you got any idea why?
blocksets do not appear in simulink
Re: blocksets do not appear in simulink
Hi Salemimoh,
few elements that may help :
- Do not install the blockset in a subdirectory of matlab
- Check that the blockset has been added to the path of matlab (File ==> Set Path ...)
The root of the blockset and its two subdirectory blocks and dspic must be in the path. (automatically done by the installer)
- play with options path cache option ; restart matlab ... (File ==> Preference ==> General ==> path cache enable/disable etc...)
Dear Lubin
It worked thank you
Emre
It worked thank you
Emre
thanks to your good work!
Users browsing this forum: No registered users and 43 guests
