dsPIC33FJ256GP710A compatible?
kin_cyber
Post by kin_cyber » Fri Jun 24, 2011 4:47 pm
Is dsPIC33FJ256GP710A compatible with your dsPIC blockset? I believe dsPIC33FJ256GP710A is a revised version of dsPIC33FJ256GP710. Hope it's fine...
Richard
Re: dsPIC33FJ256GP710A compatible?
Post by LubinKerhuel » Mon Jun 27, 2011 11:45 pm
Should works, but the A revision will be added in next release.
boyce
Post by boyce » Fri Jul 01, 2011 8:41 am
I tried download the code with the PICKit 2, but I get a message that claims the code fails the configuration check. Is there a simple work-around, such as recompiling in MPLAB? I'm using your 2010b blockset.
bmairs
Post by bmairs » Sun Aug 14, 2011 6:05 pm
I've gotten those same failures when the PICkit2 verifies the image. Try erasing the chip first and then programming, that has never failed for me.
Users browsing this forum: No registered users and 20 guests
