Support for dsPIC33xxGSxx series
Andrew
Post by Andrew » Tue Mar 29, 2011 7:16 pm
Hi ,
I saw the supporting list of chip, but didn't see the dsPIC33xxGSxx series. Will it be supported in the future? I have to use
it in my project because it has an important feature that the phase shift between differenct PWM channels is adjustable. This
feature is vital is phase-shift-dc-converter and some kind of pwm modulation in BLDC. I really hope it will be supported. Thanks!
Re: Support for dsPIC33xxGSxx series
Post by LubinKerhuel » Wed Mar 30, 2011 10:25 pm
Hi Andrew,
Theses chips are not currently supported.
I could just add their definition into the blockset ant let you make your own PWM driver usitn the C function call block.
However, an analysis should be done to check which peripheral are identical to others dsPIC, which are differents.
idem for the clock, and PLL configuration.
Could you help to speed up the process ?
Michael_hdz
Post by Michael_hdz » Tue Sep 13, 2011 12:34 pm
Dear Lubin
For me will be useful if you could add their definition, I have a proyect and I only using the ADC and the PWM Fault comparation from DAC are vital for me.
