We are getting the following error when we compile
Message: "Model Error"
Summary: "Real-Time workshop embedded coder is not licenced or not installed. The current target is C:\......\dspic.tlc"
and in the matlab command window it says....
"Warning: block diagram does not have a parameter called 'GMAKE_PLACE'"
"C30 Compiler Found"
"Real-Time Workshop build procedure for model: 'test_code' aborted due to an error."
What do you recommend???
Error when compiling
Re: Error when compiling
Hi Ellis,
The error message may be incorrect.
Could you try to re-install both compiler C30 and C32 downloaded from the microchip website ?
Let me know if it changes anything
hi Lbin
me too recieve an error when double click on configure block
it says system target file must be defined to dspic real time workshop (simulatio ==> ...)
plz help me i have a project must be done very soon
Could you post your model on the forum so as to see what is the problem ?
Users browsing this forum: No registered users and 170 guests
