just4you
Post
by just4you » Fri Sep 28, 2007 3:03 am
Lubin, I've test the new version (0.94eb)
1. character problems are fixed.
: Installation in korean windows and recognition in MATLAB 2007a are good.
2. I've test some blocks.
- test a digital i/o block with my board, then works good.
- first example shows a error message.
the followings are the grabbed in my computer.
Error building Real-Time Workshop target for block diagram 'test_01'. MATLAB error message:
Error using ==> RTW.genMakefileAndBuild at 967
Error(s) encountered while building model "test_01".
### Starting Real-Time Workshop build procedure for model: test_01
### Generating code into build directory: E:\Work\MATLAB\Test\test_01_dspic\sources
PLLPOST =
0
PLLDIV =
30
PLLPRE =
0
fcyObtained =
40000000
PLLPOST =
0
PLLDIV =
30
PLLPRE =
0
fcyObtained =
40000000
PLLPOST =
0
PLLDIV =
30
PLLPRE =
0
fcyObtained =
40000000
PLLPOST =
0
PLLDIV =
30
PLLPRE =
0
fcyObtained =
40000000
PLLPOST =
0
PLLDIV =
30
PLLPRE =
0
fcyObtained =
40000000
PLLPOST =
0
PLLDIV =
30
PLLPRE =
0
fcyObtained =
40000000
PLLPOST =
0
PLLDIV =
30
PLLPRE =
0
fcyObtained =
40000000
Number of I/O PINs used : 5
PLLPOST =
0
PLLDIV =
30
PLLPRE =
0
fcyObtained =
40000000
PLLPOST =
0
PLLDIV =
30
PLLPRE =
0
fcyObtained =
40000000
PLLPOST =
0
PLLDIV =
30
PLLPRE =
0
fcyObtained =
40000000
PLLPOST =
0
PLLDIV =
30
PLLPRE =
0
fcyObtained =
40000000
PLLPOST =
0
PLLDIV =
30
PLLPRE =
0
fcyObtained =
40000000
PLLPOST =
0
PLLDIV =
30
PLLPRE =
0
fcyObtained =
40000000
### Invoking Target Language Compiler on test_01.rtw
tlc
-r
E:\Work\MATLAB\Test\test_01_dspic\sources\test_01.rtw
E:\Work\MATLAB\dsPIC_RTW\dspic\dspic.tlc
-OE:\Work\MATLAB\Test\test_01_dspic\sources
-IE:\Work\MATLAB\dsPIC_RTW\dspic
-IE:\Work\MATLAB\dsPIC_RTW\blocks
-IE:\Work\MATLAB\Test\test_01_dspic\sources\tlc
-IC:\Program Files\MATLAB\R2007a\rtw\c\tlc\mw
-IC:\Program Files\MATLAB\R2007a\rtw\c\tlc\lib
-IC:\Program Files\MATLAB\R2007a\rtw\c\tlc\blocks
-IC:\Program Files\MATLAB\R2007a\rtw\c\tlc\fixpt
-IC:\Program Files\MATLAB\R2007a\stateflow\c\tlc
-aEnforceIntegerDowncast=1
-aFoldNonRolledExpr=1
-aInlineInvariantSignals=0
-aInlineParameters=0
-aLocalBlockOutputs=1
-aRollThreshold=5
-aInitFltsAndDblsToZero=1
-aGenerateReport=1
-aGenCodeOnly=0
-aRTWVerbose=1
-aIncludeHyperlinkInReport=1
-aLaunchReport=1
-aForceParamTrailComments=0
-aGenerateComments=1
-aIncHierarchyInIds=0
-aMaxRTWIdLen=31
-aShowEliminatedStatements=0
-aIncDataTypeInIds=0
-aInsertBlockDesc=0
-aSimulinkBlockComments=1
-aInlinedPrmAccess="Literals"
-aIsPILTarget=0
-aIncludeMdlTerminateFcn=0
-aCombineOutputUpdateFcns=1
-aSuppressErrorStatus=1
-aERTCustomFileBanners=1
-aLogVarNameModifier="rt_"
-aGenerateFullHeader=1
-aGenerateSampleERTMain=0
-aMatFileLogging=0
-aMultiInstanceERTCode=0
-aPurelyIntegerCode=0
-aPortableWordSizes=0
-aGenerateErtSFunction=0
-aGenerateASAP2=0
-aExtMode=0
-aExtModeStaticAlloc=0
-aExtModeTransport=0
-aExtModeTesting=0
-aTargetOS="BareBoardExample"
-aRateGroupingCode=1
-aRTWCAPISignals=0
-aRTWCAPIParams=0
-aRootIOStructures=0
-aOPTIM_GCC="-mcpu=33FJ128GP706 -O3 -fschedule-insns -fschedule-insns2"
-aLDFLAGS="-t --report-mem -Map ../untitled.map --heap 0 -cref"
-aLDPICTYPE="-T C:\PROGRA~1\MICROC~1\MPLABC~1\support\gld\p33fj128gp706.gld"
-aLDLIBPIC="C:\PROGRA~1\MICROC~1\MPLABC~1\lib\libpic30-coff.a C:\PROGRA~1\MICROC~1\MPLABC~1\lib\libp33FJ128GP706-coff.a C:\PROGRA~1\MICROC~1\MPLABC~1\lib\libc-coff.a C:\PROGRA~1\MICROC~1\MPLABC~1\lib\libm-coff.a"
-aPIC_INCLUDES="-IC:\PROGRA~1\MICROC~1\MPLABC~1\include"
-p10000
### Writing header file test_01_types.h
### Writing header file test_01.h
### Writing source file test_01.c
### Writing header file test_01_private.h
### Writing source file test_01_data.c
### Writing source file test_01_main.c
### Creating HTML report file test_01_codegen_rpt.html
Companie =
Embedded Coder for dsPIC V0.94eb(26-Sep-2007) for Matlab R2007a.
informations available at http://www.kerhuel.eu/
### Processing Template Makefile: E:\Work\MATLAB\dsPIC_RTW\dspic\dspic_pic30_gcc.tmf
### Creating test_01.mk from E:\Work\MATLAB\dsPIC_RTW\dspic\dspic_pic30_gcc.tmf
### Building test_01: .\test_01.bat
E:\Work\MATLAB\Test\test_01_dspic\sources>set MATLAB=C:\Program Files\MATLAB\R2007a
E:\Work\MATLAB\Test\test_01_dspic\sources>"C:\Program Files\MATLAB\R2007a\rtw\bin\win32\gmake" -f test_01.mk GENERATE_REPORT=1 ADD_MDL_NAME_TO_GLOBALS=1 MULTI_INSTANCE_CODE=0 PORTABLE_WORDSIZES=0 GENERATE_ASAP2=0 TMW_EXTMODE_TESTING=0
pic30-gcc -c -mcpu=33FJ128GP706 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007a/simulink/include -IC:\PROGRA~1\MATLAB\R2007a/extern/include -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src/ext_mode/common -IE:\Work\MATLAB\Test\test_01_dspic\sources -IE:\Work\MATLAB\Test -IC:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc -IC:\PROGRA~1\MICROC~1\MPLABC~1\include dsPIC_OutputCompare_Interrupt.c
dsPIC_OutputCompare_Interrupt.c: In function '_OC1Interrupt':
dsPIC_OutputCompare_Interrupt.c:7: warning: PSV model not specified for '_OC1Interrupt';
pic30-gcc -c -mcpu=33FJ128GP706 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007a/simulink/include -IC:\PROGRA~1\MATLAB\R2007a/extern/include -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src/ext_mode/common -IE:\Work\MATLAB\Test\test_01_dspic\sources -IE:\Work\MATLAB\Test -IC:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc -IC:\PROGRA~1\MICROC~1\MPLABC~1\include test_01_data.c
pic30-gcc -c -mcpu=33FJ128GP706 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007a/simulink/include -IC:\PROGRA~1\MATLAB\R2007a/extern/include -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src/ext_mode/common -IE:\Work\MATLAB\Test\test_01_dspic\sources -IE:\Work\MATLAB\Test -IC:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc -IC:\PROGRA~1\MICROC~1\MPLABC~1\include test_01_main.c
test_01_main.c: In function 'main':
test_01_main.c:64: warning: 'return' with a value, in function returning void
test_01_main.c:51: warning: return type of 'main' is not 'int'
pic30-gcc -c -mcpu=33FJ128GP706 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007a/simulink/include -IC:\PROGRA~1\MATLAB\R2007a/extern/include -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src/ext_mode/common -IE:\Work\MATLAB\Test\test_01_dspic\sources -IE:\Work\MATLAB\Test -IC:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc -IC:\PROGRA~1\MICROC~1\MPLABC~1\include test_01.c
test_01.c: In function 'test_01_initialize':
test_01.c:127: warning: right shift count >= width of type
test_01.c:133: error: 'OC_TIMER4_SRC' undeclared (first use in this function)
test_01.c:133: error: (Each undeclared identifier is reported only once
test_01.c:133: error: for each function it appears in.)
gmake: *** [test_01.o] Error 0xff
### Real-Time Workshop build procedure for model: 'test_01' aborted due to an error.
just4you
Post
by just4you » Fri Sep 28, 2007 3:23 am
Contrast with my model, the servos sinus examples in the packages compiled well.
My target is 33FJ128GP706.
Warning: Error evaluating 'LoadFcn' callback of Master block (mask) 'Master'. Error using ==> dsPIC_ConfigRTWOption at 34
In open at 146
In uiopen at 196
Warning: In instantiating linked block 'Servo_Sinus/Output Compare' : Output Capture Peripheral block (mask) does not have a parameter named 'NPORTS'.
In open at 146
In uiopen at 196
### Starting Real-Time Workshop build procedure for model: Servo_Sinus
### Generating code into build directory: E:\Work\MATLAB\Test\Servo_Sinus_dspic\sources
Number of I/O PINs used : 1
### Invoking Target Language Compiler on Servo_Sinus.rtw
tlc
-r
E:\Work\MATLAB\Test\Servo_Sinus_dspic\sources\Servo_Sinus.rtw
-OE:\Work\MATLAB\Test\Servo_Sinus_dspic\sources
-IE:\Work\MATLAB\Test\Servo_Sinus_dspic\sources\tlc
-aRollThreshold=5
-aGenerateReport=0
-aGenCodeOnly=0
-aRTWVerbose=1
-aIncludeHyperlinkInReport=0
-aLaunchReport=0
-aMaxRTWIdLen=31
-aInsertBlockDesc=0
-aIsPILTarget=0
-aMatFileLogging=0
-aGenerateASAP2=0
-aExtMode=0
-aExtModeTesting=0
-aRTWCAPISignals=0
-aRTWCAPIParams=0
-aLDPICTYPE="-T C:\PROGRA~1\MICROC~1\MPLABC~1\support\gld\p30f3012.gld"
-aLDLIBPIC="C:\PROGRA~1\MICROC~1\MPLABC~1\lib\libpic30-coff.a C:\PROGRA~1\MICROC~1\MPLABC~1\lib\libp30F3012-coff.a C:\PROGRA~1\MICROC~1\MPLABC~1\lib\libc-coff.a C:\PROGRA~1\MICROC~1\MPLABC~1\lib\libm-coff.a"
-p10000
### Writing header file Servo_Sinus_types.h
### Writing header file Servo_Sinus.h
### Writing source file Servo_Sinus.c
### Writing header file Servo_Sinus_private.h
### Writing source file Servo_Sinus_data.c
### Writing source file Servo_Sinus_main.c
Companie =
### Creating Servo_Sinus.mk from E:\Work\MATLAB\dsPIC_RTW\dspic\dspic_pic30_gcc.tmf
### Building Servo_Sinus: .\Servo_Sinus.bat
E:\Work\MATLAB\Test\Servo_Sinus_dspic\sources>set MATLAB=C:\Program Files\MATLAB\R2007a
E:\Work\MATLAB\Test\Servo_Sinus_dspic\sources>"C:\Program Files\MATLAB\R2007a\rtw\bin\win32\gmake" -f Servo_Sinus.mk GENERATE_REPORT=0 ADD_MDL_NAME_TO_GLOBALS=1 MULTI_INSTANCE_CODE=0 PORTABLE_WORDSIZES=0 GENERATE_ASAP2=0 TMW_EXTMODE_TESTING=0
pic30-gcc -c -mcpu=30F3012 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007a/simulink/include -IC:\PROGRA~1\MATLAB\R2007a/extern/include -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src/ext_mode/common -IE:\Work\MATLAB\Test\Servo_Sinus_dspic\sources -IE:\Work\MATLAB\Test -IC:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc -IC:\PROGRA~1\MICROC~1\MPLABC~1\include Servo_Sinus_data.c
pic30-gcc -c -mcpu=30F3012 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007a/simulink/include -IC:\PROGRA~1\MATLAB\R2007a/extern/include -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src/ext_mode/common -IE:\Work\MATLAB\Test\Servo_Sinus_dspic\sources -IE:\Work\MATLAB\Test -IC:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc -IC:\PROGRA~1\MICROC~1\MPLABC~1\include Servo_Sinus_main.c
Servo_Sinus_main.c: In function 'main':
Servo_Sinus_main.c:59: warning: 'return' with a value, in function returning void
Servo_Sinus_main.c:49: warning: return type of 'main' is not 'int'
pic30-gcc -c -mcpu=30F3012 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007a/simulink/include -IC:\PROGRA~1\MATLAB\R2007a/extern/include -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src/ext_mode/common -IE:\Work\MATLAB\Test\Servo_Sinus_dspic\sources -IE:\Work\MATLAB\Test -IC:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc -IC:\PROGRA~1\MICROC~1\MPLABC~1\include dsPIC_OutputCompare_Interrupt.c
pic30-gcc -c -mcpu=30F3012 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007a/simulink/include -IC:\PROGRA~1\MATLAB\R2007a/extern/include -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src/ext_mode/common -IE:\Work\MATLAB\Test\Servo_Sinus_dspic\sources -IE:\Work\MATLAB\Test -IC:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc -IC:\PROGRA~1\MICROC~1\MPLABC~1\include Servo_Sinus.c
pic30-gcc -c -mcpu=30F3012 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007a/simulink/include -IC:\PROGRA~1\MATLAB\R2007a/extern/include -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src/ext_mode/common -IE:\Work\MATLAB\Test\Servo_Sinus_dspic\sources -IE:\Work\MATLAB\Test -IC:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc -IC:\PROGRA~1\MICROC~1\MPLABC~1\include C:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc/rt_backsubcc_dbl.c
pic30-gcc -c -mcpu=30F3012 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007a/simulink/include -IC:\PROGRA~1\MATLAB\R2007a/extern/include -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src/ext_mode/common -IE:\Work\MATLAB\Test\Servo_Sinus_dspic\sources -IE:\Work\MATLAB\Test -IC:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc -IC:\PROGRA~1\MICROC~1\MPLABC~1\include C:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc/rt_backsubcc_sgl.c
pic30-gcc -c -mcpu=30F3012 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007a/simulink/include -IC:\PROGRA~1\MATLAB\R2007a/extern/include -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src/ext_mode/common -IE:\Work\MATLAB\Test\Servo_Sinus_dspic\sources -IE:\Work\MATLAB\Test -IC:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc -IC:\PROGRA~1\MICROC~1\MPLABC~1\include C:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc/rt_backsubrc_dbl.c
pic30-gcc -c -mcpu=30F3012 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007a/simulink/include -IC:\PROGRA~1\MATLAB\R2007a/extern/include -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src/ext_mode/common -IE:\Work\MATLAB\Test\Servo_Sinus_dspic\sources -IE:\Work\MATLAB\Test -IC:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc -IC:\PROGRA~1\MICROC~1\MPLABC~1\include C:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc/rt_backsubrc_sgl.c
pic30-gcc -c -mcpu=30F3012 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007a/simulink/include -IC:\PROGRA~1\MATLAB\R2007a/extern/include -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src/ext_mode/common -IE:\Work\MATLAB\Test\Servo_Sinus_dspic\sources -IE:\Work\MATLAB\Test -IC:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc -IC:\PROGRA~1\MICROC~1\MPLABC~1\include C:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc/rt_backsubrr_dbl.c
pic30-gcc -c -mcpu=30F3012 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007a/simulink/include -IC:\PROGRA~1\MATLAB\R2007a/extern/include -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src/ext_mode/common -IE:\Work\MATLAB\Test\Servo_Sinus_dspic\sources -IE:\Work\MATLAB\Test -IC:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc -IC:\PROGRA~1\MICROC~1\MPLABC~1\include C:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc/rt_backsubrr_sgl.c
pic30-gcc -c -mcpu=30F3012 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007a/simulink/include -IC:\PROGRA~1\MATLAB\R2007a/extern/include -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src/ext_mode/common -IE:\Work\MATLAB\Test\Servo_Sinus_dspic\sources -IE:\Work\MATLAB\Test -IC:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc -IC:\PROGRA~1\MICROC~1\MPLABC~1\include C:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc/rt_enab.c
pic30-gcc -c -mcpu=30F3012 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007a/simulink/include -IC:\PROGRA~1\MATLAB\R2007a/extern/include -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src/ext_mode/common -IE:\Work\MATLAB\Test\Servo_Sinus_dspic\sources -IE:\Work\MATLAB\Test -IC:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc -IC:\PROGRA~1\MICROC~1\MPLABC~1\include C:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc/rt_forwardsubcc_dbl.c
pic30-gcc -c -mcpu=30F3012 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007a/simulink/include -IC:\PROGRA~1\MATLAB\R2007a/extern/include -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src/ext_mode/common -IE:\Work\MATLAB\Test\Servo_Sinus_dspic\sources -IE:\Work\MATLAB\Test -IC:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc -IC:\PROGRA~1\MICROC~1\MPLABC~1\include C:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc/rt_forwardsubcc_sgl.c
pic30-gcc -c -mcpu=30F3012 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007a/simulink/include -IC:\PROGRA~1\MATLAB\R2007a/extern/include -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src/ext_mode/common -IE:\Work\MATLAB\Test\Servo_Sinus_dspic\sources -IE:\Work\MATLAB\Test -IC:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc -IC:\PROGRA~1\MICROC~1\MPLABC~1\include C:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc/rt_forwardsubcr_dbl.c
pic30-gcc -c -mcpu=30F3012 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007a/simulink/include -IC:\PROGRA~1\MATLAB\R2007a/extern/include -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src/ext_mode/common -IE:\Work\MATLAB\Test\Servo_Sinus_dspic\sources -IE:\Work\MATLAB\Test -IC:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc -IC:\PROGRA~1\MICROC~1\MPLABC~1\include C:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc/rt_forwardsubcr_sgl.c
pic30-gcc -c -mcpu=30F3012 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007a/simulink/include -IC:\PROGRA~1\MATLAB\R2007a/extern/include -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src/ext_mode/common -IE:\Work\MATLAB\Test\Servo_Sinus_dspic\sources -IE:\Work\MATLAB\Test -IC:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc -IC:\PROGRA~1\MICROC~1\MPLABC~1\include C:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc/rt_forwardsubrc_dbl.c
pic30-gcc -c -mcpu=30F3012 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007a/simulink/include -IC:\PROGRA~1\MATLAB\R2007a/extern/include -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src/ext_mode/common -IE:\Work\MATLAB\Test\Servo_Sinus_dspic\sources -IE:\Work\MATLAB\Test -IC:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc -IC:\PROGRA~1\MICROC~1\MPLABC~1\include C:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc/rt_forwardsubrc_sgl.c
pic30-gcc -c -mcpu=30F3012 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007a/simulink/include -IC:\PROGRA~1\MATLAB\R2007a/extern/include -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src/ext_mode/common -IE:\Work\MATLAB\Test\Servo_Sinus_dspic\sources -IE:\Work\MATLAB\Test -IC:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc -IC:\PROGRA~1\MICROC~1\MPLABC~1\include C:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc/rt_forwardsubrr_dbl.c
pic30-gcc -c -mcpu=30F3012 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007a/simulink/include -IC:\PROGRA~1\MATLAB\R2007a/extern/include -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src/ext_mode/common -IE:\Work\MATLAB\Test\Servo_Sinus_dspic\sources -IE:\Work\MATLAB\Test -IC:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc -IC:\PROGRA~1\MICROC~1\MPLABC~1\include C:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc/rt_forwardsubrr_sgl.c
pic30-gcc -c -mcpu=30F3012 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007a/simulink/include -IC:\PROGRA~1\MATLAB\R2007a/extern/include -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src/ext_mode/common -IE:\Work\MATLAB\Test\Servo_Sinus_dspic\sources -IE:\Work\MATLAB\Test -IC:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc -IC:\PROGRA~1\MICROC~1\MPLABC~1\include C:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc/rt_hypot.c
pic30-gcc -c -mcpu=30F3012 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007a/simulink/include -IC:\PROGRA~1\MATLAB\R2007a/extern/include -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src/ext_mode/common -IE:\Work\MATLAB\Test\Servo_Sinus_dspic\sources -IE:\Work\MATLAB\Test -IC:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc -IC:\PROGRA~1\MICROC~1\MPLABC~1\include C:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc/rt_hypot32.c
pic30-gcc -c -mcpu=30F3012 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007a/simulink/include -IC:\PROGRA~1\MATLAB\R2007a/extern/include -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src/ext_mode/common -IE:\Work\MATLAB\Test\Servo_Sinus_dspic\sources -IE:\Work\MATLAB\Test -IC:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc -IC:\PROGRA~1\MICROC~1\MPLABC~1\include C:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc/rt_i32zcfcn.c
pic30-gcc -c -mcpu=30F3012 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007a/simulink/include -IC:\PROGRA~1\MATLAB\R2007a/extern/include -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src/ext_mode/common -IE:\Work\MATLAB\Test\Servo_Sinus_dspic\sources -IE:\Work\MATLAB\Test -IC:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc -IC:\PROGRA~1\MICROC~1\MPLABC~1\include C:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc/rt_look.c
pic30-gcc -c -mcpu=30F3012 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007a/simulink/include -IC:\PROGRA~1\MATLAB\R2007a/extern/include -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src/ext_mode/common -IE:\Work\MATLAB\Test\Servo_Sinus_dspic\sources -IE:\Work\MATLAB\Test -IC:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc -IC:\PROGRA~1\MICROC~1\MPLABC~1\include C:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc/rt_look1d.c
pic30-gcc -c -mcpu=30F3012 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007a/simulink/include -IC:\PROGRA~1\MATLAB\R2007a/extern/include -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src/ext_mode/common -IE:\Work\MATLAB\Test\Servo_Sinus_dspic\sources -IE:\Work\MATLAB\Test -IC:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc -IC:\PROGRA~1\MICROC~1\MPLABC~1\include C:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc/rt_look1d32.c
pic30-gcc -c -mcpu=30F3012 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007a/simulink/include -IC:\PROGRA~1\MATLAB\R2007a/extern/include -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src/ext_mode/common -IE:\Work\MATLAB\Test\Servo_Sinus_dspic\sources -IE:\Work\MATLAB\Test -IC:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc -IC:\PROGRA~1\MICROC~1\MPLABC~1\include C:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc/rt_look2d32_general.c
pic30-gcc -c -mcpu=30F3012 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007a/simulink/include -IC:\PROGRA~1\MATLAB\R2007a/extern/include -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src/ext_mode/common -IE:\Work\MATLAB\Test\Servo_Sinus_dspic\sources -IE:\Work\MATLAB\Test -IC:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc -IC:\PROGRA~1\MICROC~1\MPLABC~1\include C:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc/rt_look2d32_normal.c
pic30-gcc -c -mcpu=30F3012 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007a/simulink/include -IC:\PROGRA~1\MATLAB\R2007a/extern/include -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src/ext_mode/common -IE:\Work\MATLAB\Test\Servo_Sinus_dspic\sources -IE:\Work\MATLAB\Test -IC:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc -IC:\PROGRA~1\MICROC~1\MPLABC~1\include C:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc/rt_look2d_general.c
pic30-gcc -c -mcpu=30F3012 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007a/simulink/include -IC:\PROGRA~1\MATLAB\R2007a/extern/include -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src/ext_mode/common -IE:\Work\MATLAB\Test\Servo_Sinus_dspic\sources -IE:\Work\MATLAB\Test -IC:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc -IC:\PROGRA~1\MICROC~1\MPLABC~1\include C:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc/rt_look2d_normal.c
pic30-gcc -c -mcpu=30F3012 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007a/simulink/include -IC:\PROGRA~1\MATLAB\R2007a/extern/include -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src/ext_mode/common -IE:\Work\MATLAB\Test\Servo_Sinus_dspic\sources -IE:\Work\MATLAB\Test -IC:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc -IC:\PROGRA~1\MICROC~1\MPLABC~1\include C:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc/rt_look32.c
pic30-gcc -c -mcpu=30F3012 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007a/simulink/include -IC:\PROGRA~1\MATLAB\R2007a/extern/include -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src/ext_mode/common -IE:\Work\MATLAB\Test\Servo_Sinus_dspic\sources -IE:\Work\MATLAB\Test -IC:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc -IC:\PROGRA~1\MICROC~1\MPLABC~1\include C:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc/rt_lu_cplx.c
pic30-gcc -c -mcpu=30F3012 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007a/simulink/include -IC:\PROGRA~1\MATLAB\R2007a/extern/include -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src/ext_mode/common -IE:\Work\MATLAB\Test\Servo_Sinus_dspic\sources -IE:\Work\MATLAB\Test -IC:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc -IC:\PROGRA~1\MICROC~1\MPLABC~1\include C:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc/rt_lu_cplx_sgl.c
pic30-gcc -c -mcpu=30F3012 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007a/simulink/include -IC:\PROGRA~1\MATLAB\R2007a/extern/include -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src/ext_mode/common -IE:\Work\MATLAB\Test\Servo_Sinus_dspic\sources -IE:\Work\MATLAB\Test -IC:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc -IC:\PROGRA~1\MICROC~1\MPLABC~1\include C:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc/rt_lu_real.c
pic30-gcc -c -mcpu=30F3012 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007a/simulink/include -IC:\PROGRA~1\MATLAB\R2007a/extern/include -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src/ext_mode/common -IE:\Work\MATLAB\Test\Servo_Sinus_dspic\sources -IE:\Work\MATLAB\Test -IC:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc -IC:\PROGRA~1\MICROC~1\MPLABC~1\include C:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc/rt_lu_real_sgl.c
pic30-gcc -c -mcpu=30F3012 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007a/simulink/include -IC:\PROGRA~1\MATLAB\R2007a/extern/include -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src/ext_mode/common -IE:\Work\MATLAB\Test\Servo_Sinus_dspic\sources -IE:\Work\MATLAB\Test -IC:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc -IC:\PROGRA~1\MICROC~1\MPLABC~1\include C:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc/rt_matdivcc_dbl.c
pic30-gcc -c -mcpu=30F3012 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007a/simulink/include -IC:\PROGRA~1\MATLAB\R2007a/extern/include -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src/ext_mode/common -IE:\Work\MATLAB\Test\Servo_Sinus_dspic\sources -IE:\Work\MATLAB\Test -IC:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc -IC:\PROGRA~1\MICROC~1\MPLABC~1\include C:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc/rt_matdivcc_sgl.c
pic30-gcc -c -mcpu=30F3012 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007a/simulink/include -IC:\PROGRA~1\MATLAB\R2007a/extern/include -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src/ext_mode/common -IE:\Work\MATLAB\Test\Servo_Sinus_dspic\sources -IE:\Work\MATLAB\Test -IC:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc -IC:\PROGRA~1\MICROC~1\MPLABC~1\include C:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc/rt_matdivcr_dbl.c
pic30-gcc -c -mcpu=30F3012 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007a/simulink/include -IC:\PROGRA~1\MATLAB\R2007a/extern/include -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src/ext_mode/common -IE:\Work\MATLAB\Test\Servo_Sinus_dspic\sources -IE:\Work\MATLAB\Test -IC:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc -IC:\PROGRA~1\MICROC~1\MPLABC~1\include C:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc/rt_matdivcr_sgl.c
pic30-gcc -c -mcpu=30F3012 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007a/simulink/include -IC:\PROGRA~1\MATLAB\R2007a/extern/include -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src/ext_mode/common -IE:\Work\MATLAB\Test\Servo_Sinus_dspic\sources -IE:\Work\MATLAB\Test -IC:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc -IC:\PROGRA~1\MICROC~1\MPLABC~1\include C:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc/rt_matdivrc_dbl.c
pic30-gcc -c -mcpu=30F3012 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007a/simulink/include -IC:\PROGRA~1\MATLAB\R2007a/extern/include -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src/ext_mode/common -IE:\Work\MATLAB\Test\Servo_Sinus_dspic\sources -IE:\Work\MATLAB\Test -IC:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc -IC:\PROGRA~1\MICROC~1\MPLABC~1\include C:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc/rt_matdivrc_sgl.c
pic30-gcc -c -mcpu=30F3012 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007a/simulink/include -IC:\PROGRA~1\MATLAB\R2007a/extern/include -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src/ext_mode/common -IE:\Work\MATLAB\Test\Servo_Sinus_dspic\sources -IE:\Work\MATLAB\Test -IC:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc -IC:\PROGRA~1\MICROC~1\MPLABC~1\include C:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc/rt_matdivrr_dbl.c
pic30-gcc -c -mcpu=30F3012 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007a/simulink/include -IC:\PROGRA~1\MATLAB\R2007a/extern/include -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src/ext_mode/common -IE:\Work\MATLAB\Test\Servo_Sinus_dspic\sources -IE:\Work\MATLAB\Test -IC:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc -IC:\PROGRA~1\MICROC~1\MPLABC~1\include C:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc/rt_matdivrr_sgl.c
pic30-gcc -c -mcpu=30F3012 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007a/simulink/include -IC:\PROGRA~1\MATLAB\R2007a/extern/include -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src/ext_mode/common -IE:\Work\MATLAB\Test\Servo_Sinus_dspic\sources -IE:\Work\MATLAB\Test -IC:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc -IC:\PROGRA~1\MICROC~1\MPLABC~1\include C:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc/rt_matmultandinccc_dbl.c
pic30-gcc -c -mcpu=30F3012 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007a/simulink/include -IC:\PROGRA~1\MATLAB\R2007a/extern/include -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src/ext_mode/common -IE:\Work\MATLAB\Test\Servo_Sinus_dspic\sources -IE:\Work\MATLAB\Test -IC:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc -IC:\PROGRA~1\MICROC~1\MPLABC~1\include C:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc/rt_matmultandinccc_sgl.c
pic30-gcc -c -mcpu=30F3012 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007a/simulink/include -IC:\PROGRA~1\MATLAB\R2007a/extern/include -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src/ext_mode/common -IE:\Work\MATLAB\Test\Servo_Sinus_dspic\sources -IE:\Work\MATLAB\Test -IC:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc -IC:\PROGRA~1\MICROC~1\MPLABC~1\include C:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc/rt_matmultandinccr_dbl.c
pic30-gcc -c -mcpu=30F3012 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007a/simulink/include -IC:\PROGRA~1\MATLAB\R2007a/extern/include -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src/ext_mode/common -IE:\Work\MATLAB\Test\Servo_Sinus_dspic\sources -IE:\Work\MATLAB\Test -IC:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc -IC:\PROGRA~1\MICROC~1\MPLABC~1\include C:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc/rt_matmultandinccr_sgl.c
pic30-gcc -c -mcpu=30F3012 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007a/simulink/include -IC:\PROGRA~1\MATLAB\R2007a/extern/include -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src/ext_mode/common -IE:\Work\MATLAB\Test\Servo_Sinus_dspic\sources -IE:\Work\MATLAB\Test -IC:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc -IC:\PROGRA~1\MICROC~1\MPLABC~1\include C:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc/rt_matmultandincrc_dbl.c
pic30-gcc -c -mcpu=30F3012 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007a/simulink/include -IC:\PROGRA~1\MATLAB\R2007a/extern/include -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src/ext_mode/common -IE:\Work\MATLAB\Test\Servo_Sinus_dspic\sources -IE:\Work\MATLAB\Test -IC:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc -IC:\PROGRA~1\MICROC~1\MPLABC~1\include C:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc/rt_matmultandincrc_sgl.c
pic30-gcc -c -mcpu=30F3012 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007a/simulink/include -IC:\PROGRA~1\MATLAB\R2007a/extern/include -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src/ext_mode/common -IE:\Work\MATLAB\Test\Servo_Sinus_dspic\sources -IE:\Work\MATLAB\Test -IC:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc -IC:\PROGRA~1\MICROC~1\MPLABC~1\include C:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc/rt_matmultandincrr_dbl.c
pic30-gcc -c -mcpu=30F3012 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007a/simulink/include -IC:\PROGRA~1\MATLAB\R2007a/extern/include -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src/ext_mode/common -IE:\Work\MATLAB\Test\Servo_Sinus_dspic\sources -IE:\Work\MATLAB\Test -IC:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc -IC:\PROGRA~1\MICROC~1\MPLABC~1\include C:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc/rt_matmultandincrr_sgl.c
pic30-gcc -c -mcpu=30F3012 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007a/simulink/include -IC:\PROGRA~1\MATLAB\R2007a/extern/include -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src/ext_mode/common -IE:\Work\MATLAB\Test\Servo_Sinus_dspic\sources -IE:\Work\MATLAB\Test -IC:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc -IC:\PROGRA~1\MICROC~1\MPLABC~1\include C:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc/rt_matmultcc_dbl.c
pic30-gcc -c -mcpu=30F3012 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007a/simulink/include -IC:\PROGRA~1\MATLAB\R2007a/extern/include -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src/ext_mode/common -IE:\Work\MATLAB\Test\Servo_Sinus_dspic\sources -IE:\Work\MATLAB\Test -IC:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc -IC:\PROGRA~1\MICROC~1\MPLABC~1\include C:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc/rt_matmultcc_sgl.c
pic30-gcc -c -mcpu=30F3012 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007a/simulink/include -IC:\PROGRA~1\MATLAB\R2007a/extern/include -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src/ext_mode/common -IE:\Work\MATLAB\Test\Servo_Sinus_dspic\sources -IE:\Work\MATLAB\Test -IC:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc -IC:\PROGRA~1\MICROC~1\MPLABC~1\include C:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc/rt_matmultcr_dbl.c
pic30-gcc -c -mcpu=30F3012 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007a/simulink/include -IC:\PROGRA~1\MATLAB\R2007a/extern/include -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src/ext_mode/common -IE:\Work\MATLAB\Test\Servo_Sinus_dspic\sources -IE:\Work\MATLAB\Test -IC:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc -IC:\PROGRA~1\MICROC~1\MPLABC~1\include C:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc/rt_matmultcr_sgl.c
pic30-gcc -c -mcpu=30F3012 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007a/simulink/include -IC:\PROGRA~1\MATLAB\R2007a/extern/include -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src/ext_mode/common -IE:\Work\MATLAB\Test\Servo_Sinus_dspic\sources -IE:\Work\MATLAB\Test -IC:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc -IC:\PROGRA~1\MICROC~1\MPLABC~1\include C:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc/rt_matmultrc_dbl.c
pic30-gcc -c -mcpu=30F3012 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007a/simulink/include -IC:\PROGRA~1\MATLAB\R2007a/extern/include -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src/ext_mode/common -IE:\Work\MATLAB\Test\Servo_Sinus_dspic\sources -IE:\Work\MATLAB\Test -IC:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc -IC:\PROGRA~1\MICROC~1\MPLABC~1\include C:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc/rt_matmultrc_sgl.c
pic30-gcc -c -mcpu=30F3012 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007a/simulink/include -IC:\PROGRA~1\MATLAB\R2007a/extern/include -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src/ext_mode/common -IE:\Work\MATLAB\Test\Servo_Sinus_dspic\sources -IE:\Work\MATLAB\Test -IC:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc -IC:\PROGRA~1\MICROC~1\MPLABC~1\include C:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc/rt_matmultrr_dbl.c
pic30-gcc -c -mcpu=30F3012 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007a/simulink/include -IC:\PROGRA~1\MATLAB\R2007a/extern/include -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src/ext_mode/common -IE:\Work\MATLAB\Test\Servo_Sinus_dspic\sources -IE:\Work\MATLAB\Test -IC:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc -IC:\PROGRA~1\MICROC~1\MPLABC~1\include C:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc/rt_matmultrr_sgl.c
pic30-gcc -c -mcpu=30F3012 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007a/simulink/include -IC:\PROGRA~1\MATLAB\R2007a/extern/include -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src/ext_mode/common -IE:\Work\MATLAB\Test\Servo_Sinus_dspic\sources -IE:\Work\MATLAB\Test -IC:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc -IC:\PROGRA~1\MICROC~1\MPLABC~1\include C:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc/rt_nrand.c
pic30-gcc -c -mcpu=30F3012 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007a/simulink/include -IC:\PROGRA~1\MATLAB\R2007a/extern/include -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src/ext_mode/common -IE:\Work\MATLAB\Test\Servo_Sinus_dspic\sources -IE:\Work\MATLAB\Test -IC:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc -IC:\PROGRA~1\MICROC~1\MPLABC~1\include C:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc/rt_sat_div_int16.c
pic30-gcc -c -mcpu=30F3012 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007a/simulink/include -IC:\PROGRA~1\MATLAB\R2007a/extern/include -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src/ext_mode/common -IE:\Work\MATLAB\Test\Servo_Sinus_dspic\sources -IE:\Work\MATLAB\Test -IC:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc -IC:\PROGRA~1\MICROC~1\MPLABC~1\include C:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc/rt_sat_div_int32.c
pic30-gcc -c -mcpu=30F3012 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007a/simulink/include -IC:\PROGRA~1\MATLAB\R2007a/extern/include -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src/ext_mode/common -IE:\Work\MATLAB\Test\Servo_Sinus_dspic\sources -IE:\Work\MATLAB\Test -IC:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc -IC:\PROGRA~1\MICROC~1\MPLABC~1\include C:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc/rt_sat_div_int8.c
pic30-gcc -c -mcpu=30F3012 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007a/simulink/include -IC:\PROGRA~1\MATLAB\R2007a/extern/include -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src/ext_mode/common -IE:\Work\MATLAB\Test\Servo_Sinus_dspic\sources -IE:\Work\MATLAB\Test -IC:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc -IC:\PROGRA~1\MICROC~1\MPLABC~1\include C:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc/rt_sat_div_uint16.c
pic30-gcc -c -mcpu=30F3012 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007a/simulink/include -IC:\PROGRA~1\MATLAB\R2007a/extern/include -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src/ext_mode/common -IE:\Work\MATLAB\Test\Servo_Sinus_dspic\sources -IE:\Work\MATLAB\Test -IC:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc -IC:\PROGRA~1\MICROC~1\MPLABC~1\include C:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc/rt_sat_div_uint32.c
pic30-gcc -c -mcpu=30F3012 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007a/simulink/include -IC:\PROGRA~1\MATLAB\R2007a/extern/include -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src/ext_mode/common -IE:\Work\MATLAB\Test\Servo_Sinus_dspic\sources -IE:\Work\MATLAB\Test -IC:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc -IC:\PROGRA~1\MICROC~1\MPLABC~1\include C:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc/rt_sat_div_uint8.c
pic30-gcc -c -mcpu=30F3012 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007a/simulink/include -IC:\PROGRA~1\MATLAB\R2007a/extern/include -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src/ext_mode/common -IE:\Work\MATLAB\Test\Servo_Sinus_dspic\sources -IE:\Work\MATLAB\Test -IC:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc -IC:\PROGRA~1\MICROC~1\MPLABC~1\include C:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc/rt_sat_prod_int16.c
pic30-gcc -c -mcpu=30F3012 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007a/simulink/include -IC:\PROGRA~1\MATLAB\R2007a/extern/include -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src/ext_mode/common -IE:\Work\MATLAB\Test\Servo_Sinus_dspic\sources -IE:\Work\MATLAB\Test -IC:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc -IC:\PROGRA~1\MICROC~1\MPLABC~1\include C:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc/rt_sat_prod_int32.c
pic30-gcc -c -mcpu=30F3012 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007a/simulink/include -IC:\PROGRA~1\MATLAB\R2007a/extern/include -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src/ext_mode/common -IE:\Work\MATLAB\Test\Servo_Sinus_dspic\sources -IE:\Work\MATLAB\Test -IC:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc -IC:\PROGRA~1\MICROC~1\MPLABC~1\include C:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc/rt_sat_prod_int8.c
pic30-gcc -c -mcpu=30F3012 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007a/simulink/include -IC:\PROGRA~1\MATLAB\R2007a/extern/include -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src/ext_mode/common -IE:\Work\MATLAB\Test\Servo_Sinus_dspic\sources -IE:\Work\MATLAB\Test -IC:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc -IC:\PROGRA~1\MICROC~1\MPLABC~1\include C:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc/rt_sat_prod_uint16.c
pic30-gcc -c -mcpu=30F3012 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007a/simulink/include -IC:\PROGRA~1\MATLAB\R2007a/extern/include -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src/ext_mode/common -IE:\Work\MATLAB\Test\Servo_Sinus_dspic\sources -IE:\Work\MATLAB\Test -IC:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc -IC:\PROGRA~1\MICROC~1\MPLABC~1\include C:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc/rt_sat_prod_uint32.c
pic30-gcc -c -mcpu=30F3012 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007a/simulink/include -IC:\PROGRA~1\MATLAB\R2007a/extern/include -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src/ext_mode/common -IE:\Work\MATLAB\Test\Servo_Sinus_dspic\sources -IE:\Work\MATLAB\Test -IC:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc -IC:\PROGRA~1\MICROC~1\MPLABC~1\include C:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc/rt_sat_prod_uint8.c
pic30-gcc -c -mcpu=30F3012 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007a/simulink/include -IC:\PROGRA~1\MATLAB\R2007a/extern/include -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src/ext_mode/common -IE:\Work\MATLAB\Test\Servo_Sinus_dspic\sources -IE:\Work\MATLAB\Test -IC:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc -IC:\PROGRA~1\MICROC~1\MPLABC~1\include C:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc/rt_urand.c
pic30-gcc -c -mcpu=30F3012 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007a/simulink/include -IC:\PROGRA~1\MATLAB\R2007a/extern/include -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007a/rtw/c/src/ext_mode/common -IE:\Work\MATLAB\Test\Servo_Sinus_dspic\sources -IE:\Work\MATLAB\Test -IC:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc -IC:\PROGRA~1\MICROC~1\MPLABC~1\include C:\PROGRA~1\MATLAB\R2007a\rtw\c\libsrc/rt_zcfcn.c
"### Creating rtwlib.a "
pic30-ar -r rtwlib.a rt_backsubcc_dbl.o rt_backsubcc_sgl.o rt_backsubrc_dbl.o rt_backsubrc_sgl.o rt_backsubrr_dbl.o rt_backsubrr_sgl.o rt_enab.o rt_forwardsubcc_dbl.o rt_forwardsubcc_sgl.o rt_forwardsubcr_dbl.o rt_forwardsubcr_sgl.o rt_forwardsubrc_dbl.o rt_forwardsubrc_sgl.o rt_forwardsubrr_dbl.o rt_forwardsubrr_sgl.o rt_hypot.o rt_hypot32.o rt_i32zcfcn.o rt_look.o rt_look1d.o rt_look1d32.o rt_look2d32_general.o rt_look2d32_normal.o rt_look2d_general.o rt_look2d_normal.o rt_look32.o rt_lu_cplx.o rt_lu_cplx_sgl.o rt_lu_real.o rt_lu_real_sgl.o rt_matdivcc_dbl.o rt_matdivcc_sgl.o rt_matdivcr_dbl.o rt_matdivcr_sgl.o rt_matdivrc_dbl.o rt_matdivrc_sgl.o rt_matdivrr_dbl.o rt_matdivrr_sgl.o rt_matmultandinccc_dbl.o rt_matmultandinccc_sgl.o rt_matmultandinccr_dbl.o rt_matmultandinccr_sgl.o rt_matmultandincrc_dbl.o rt_matmultandincrc_sgl.o rt_matmultandincrr_dbl.o rt_matmultandincrr_sgl.o rt_matmultcc_dbl.o rt_matmultcc_sgl.o rt_matmultcr_dbl.o rt_matmultcr_sgl.o rt_matmultrc_dbl.o rt_matmultrc_sgl.o rt_matmultrr_dbl.o rt_matmultrr_sgl.o rt_nrand.o rt_sat_div_int16.o rt_sat_div_int32.o rt_sat_div_int8.o rt_sat_div_uint16.o rt_sat_div_uint32.o rt_sat_div_uint8.o rt_sat_prod_int16.o rt_sat_prod_int32.o rt_sat_prod_int8.o rt_sat_prod_uint16.o rt_sat_prod_uint32.o rt_sat_prod_uint8.o rt_urand.o rt_zcfcn.o
"### rtwlib.a Created"
pic30-ld -t --report-mem -Map ../untitled.map --heap 0 -cref -T C:\PROGRA~1\MICROC~1\MPLABC~1\support\gld\p30f3012.gld -o ..\../Servo_Sinus.coff Servo_Sinus_data.o Servo_Sinus_main.o dsPIC_OutputCompare_Interrupt.o Servo_Sinus.o rtwlib.a C:\PROGRA~1\MICROC~1\MPLABC~1\lib\libpic30-coff.a C:\PROGRA~1\MICROC~1\MPLABC~1\lib\libp30F3012-coff.a C:\PROGRA~1\MICROC~1\MPLABC~1\lib\libc-coff.a C:\PROGRA~1\MICROC~1\MPLABC~1\lib\libm-coff.a
C:\Program Files\Microchip\MPLAB C30\bin\pic30-coff-ld.exe: mode pic30_coff
Servo_Sinus_data.o
Servo_Sinus_main.o
Servo_Sinus.o
(C:\PROGRA~1\MICROC~1\MPLABC~1\lib\libpic30-coff.a)crt1.o
(C:\PROGRA~1\MICROC~1\MPLABC~1\lib\libpic30-coff.a)crt0.o
(C:\PROGRA~1\MICROC~1\MPLABC~1\lib\libp30F3012-coff.a)ConfigIntTimer1.o
(C:\PROGRA~1\MICROC~1\MPLABC~1\lib\libp30F3012-coff.a)ConfigIntTimer2.o
(C:\PROGRA~1\MICROC~1\MPLABC~1\lib\libp30F3012-coff.a)OpenTimer2.o
(C:\PROGRA~1\MICROC~1\MPLABC~1\lib\libp30F3012-coff.a)OpenOC1.o
(C:\PROGRA~1\MICROC~1\MPLABC~1\lib\libp30F3012-coff.a)ConfigIntOC1.o
(C:\PROGRA~1\MICROC~1\MPLABC~1\lib\libm-coff.a)floatsisf.o
(C:\PROGRA~1\MICROC~1\MPLABC~1\lib\libm-coff.a)addsf3.o
(C:\PROGRA~1\MICROC~1\MPLABC~1\lib\libm-coff.a)mulsf3.o
(C:\PROGRA~1\MICROC~1\MPLABC~1\lib\libm-coff.a)divsf3.o
(C:\PROGRA~1\MICROC~1\MPLABC~1\lib\libm-coff.a)sinf.o
(C:\PROGRA~1\MICROC~1\MPLABC~1\lib\libm-coff.a)floorf.o
(C:\PROGRA~1\MICROC~1\MPLABC~1\lib\libm-coff.a)fmodf.o
(C:\PROGRA~1\MICROC~1\MPLABC~1\lib\libm-coff.a)feqltle.o
(C:\PROGRA~1\MICROC~1\MPLABC~1\lib\libm-coff.a)fixunssfsi.o
(C:\PROGRA~1\MICROC~1\MPLABC~1\lib\libm-coff.a)fpack.o
(C:\PROGRA~1\MICROC~1\MPLABC~1\lib\libm-coff.a)funpack2.o
(C:\PROGRA~1\MICROC~1\MPLABC~1\lib\libm-coff.a)futil.o
(C:\PROGRA~1\MICROC~1\MPLABC~1\lib\libm-coff.a)sincosf.o
(C:\PROGRA~1\MICROC~1\MPLABC~1\lib\libm-coff.a)fchop.o
(C:\PROGRA~1\MICROC~1\MPLABC~1\lib\libm-coff.a)fmodrem.o
(C:\PROGRA~1\MICROC~1\MPLABC~1\lib\libm-coff.a)fcompare.o
(C:\PROGRA~1\MICROC~1\MPLABC~1\lib\libm-coff.a)funpack.o
(C:\PROGRA~1\MICROC~1\MPLABC~1\lib\libm-coff.a)errno.o
(C:\PROGRA~1\MICROC~1\MPLABC~1\lib\libm-coff.a)fixsfsi.o
Program Memory Usage
section address length (PC units) length (bytes) (dec)
.reset 0 0x4 0x6 (6)
.ivt 0x4 0x7c 0xba (186)
.aivt 0x84 0x7c 0xba (186)
.text 0x100 0x750 0xaf8 (2808)
.dinit 0x850 0x2c 0x42 (66)
.isr 0x87c 0x2 0x3 (3)
__FOSC 0xf80000 0x2 0x3 (3)
__FWDT 0xf80002 0x2 0x3 (3)
__FBORPOR 0xf80004 0x2 0x3 (3)
__FGS 0xf8000a 0x2 0x3 (3)
Total program memory used (bytes): 0xcc3 (3267) 13%
Data Memory Usage
section address alignment gaps total length (dec)
.ndata 0x800 0 0x12 (18)
.nbss 0x812 0 0x6 (6)
.nbss 0x818 0 0x4 (4)
.nbss 0x81c 0 0x2 (2)
.nbss 0x81e 0 0x2 (2)
Total data memory used (bytes): 0x20 (32) 1%
Dynamic Memory Usage
region address maximum length (dec)
heap 0 0 (0)
stack 0x820 0x7e0 (2016)
Maximum dynamic memory (bytes): 0x7e0 (2016)
"*** Created "executable": ..\../Servo_Sinus.coff"
pic30-coff-bin2hex ..\../Servo_Sinus.coff
### Successful completion of Real-Time Workshop build procedure for model: Servo_Sinus
Post
by LubinKerhuel » Fri Sep 28, 2007 8:00 am
Could you provide me with the mdl file that does not compile ?
Post
by LubinKerhuel » Sat Sep 29, 2007 1:32 pm
I find the bug; While I correct it, you could avoid it by setting the auto configuration of the timer4 and above to off by setting to 0 at :
dsPIC MASTER block dialog box
tab : Real Time - Quartz
Config Timer [2 3 4 ...]
The value should look like this: [-1 -1 0 0 ...]
The number of zero depends on the number of independent timer of the PIC.
just4you
Post
by just4you » Mon Oct 01, 2007 1:58 am
[-1 -1 0 0] means timer 3, 4 off, is it?
Timer 4 is the source of OC1 block with dsPIC33FJ128GP706.
hmm.. I think it's not a good configuration.
I'll send my test model file to you by e-mail....
P.S > I hope I can upload a file in the forum site..
Post
by LubinKerhuel » Sat Oct 06, 2007 1:31 pm
Very nice bug!
Timers are assigned automatically to get the best result (using my criterion!)
Unfortunately, Input Capture and Output Compare could only be assigned to Timer 2 or to Timer 3.
The optimization algorithm that set timer's prescaler and assign Timer did not take into account this constraint and sometimes IC or OC peripheral were assigned to a Timer above 3 ( 4 or 5 for example)
With the version 0.95a of the toolbox,
The bug is corrected! The optimization algorithm takes into account this constraint and IC and OC could only be assigned to Timer 2 or Timer 3!
Download the last version :
http://www.kerhuel.eu/RTWdsPIC/download.html
Post
by LubinKerhuel » Sat Dec 15, 2007 2:03 pm
just4you wrote:P.S > I hope I can upload a file in the forum site..
It is now possible to upload files on the forum !
Users browsing this forum: No registered users and 84 guests
