Target for dsPIC's errors on my system...
I'm korean and I also want to make the target for dsPIC.
but the master of this forum has done.
so I decide to change my purpose to use this tool.
However, target for dsPIC makes some troubles..
so I can't try the examples on the web site.
1. windows character encoding problem
the toolbox is made with 'windows-1252'
'windows-949' is used in my coutry..
When load the "\blocks\dsPICdrivers.mdl", 2 kind of errors are occured.
'§' and '°' character makes troubles.
korean is one of representative 2-byte characters. Therefore it runs well on the korean windows, I expect that it runs well on other 2-byte chracter system.
http://cafefiles.naver.net/data26/2007/ ... st4u78.jpg
I'm using the slCharacterEncoding() function to avoid the upper problem.
using the 'windows-1252', I cann't save well. so this must be improved.
2. master & configuration block error
when double clicking the both blocks to set the master block and configuration block, the system show the following errors.
Master block settings are not shown. How can I avoid the messages?
P.S > I hope that this article can contain the image files.
I can't upload the images, link is just allowed.
It's very inconvenient..
0.94e the newest version has also character problems
The master of this forum anounced release of 0.94e version.
Perhaps This version works in japanese windows well, but it's now working in korean windows.
'§' and '°' characters make problems.
0.94eb toolbox works..
I've tested the new version of the Embedded workshop for dsPIC.
This version of dsPIC RTW generates the compiled codes.
(Embedded Coder for dsPIC V0.94eb works in Korean Windows and MATLAB 2007a)
I'll report more results after some more tests.
Bug corrected
The new version with bug corrected is now available : V0.95a
Several improvement have also been made to this version which now support 56 Microcontrolleurs.
Download it here : http://www.kerhuel.eu/RTWdsPIC/download.html
Release notes can be found here : http://www.kerhuel.eu/RTWdsPIC/ReleaseNotes.html
Users browsing this forum: No registered users and 71 guests
