Hi guys
I'm trying to perform a serial communication among Simulink and dspic33F. When I generate a signal within the microcontroller I can view this signal in an other file using instrument control box library. But when I use the UART Rx block to catch the signals that is generated outside the microcontroller, the signal is simply zero viewed from the microcontroller.
I am using a embedded target for microchip dsPIC library. I'll send the two files I'm using to perform this.
Any help would be very grateful.
UART Rx configuration
- serialcommunication.mdl
- (30.45 KiB) Downloaded 1633 times
- serialsend.mdl
- (21.17 KiB) Downloaded 1586 times
Users browsing this forum: No registered users and 62 guests
