Heap can't be configured for MPLAB
Posted: Wed Feb 08, 2012 8:22 pm
If you specify a heap size for your project in Simulink under Code Generation->DsPIC options->LDFLAGS then this same setting won't apply to the generated MPLAB 8 project and you'll need to manually specify a heap size. This means that the default project created by your blockset when a heap is specified doesn't compile.
