MPLAB 8.x project not generated properly during compile
Posted: Mon Nov 07, 2011 8:25 pm
I'm compiling a project and the MPLAB 8.x project isn't being properly generated. I'm seeing the following at the end of code generation:
My project does include a variety of external C files, though none have the path '\circBuffer.c':
I've also played with location of circBuffer.c within the list of files to include and it made no difference whether it was at the head of the list or towards the bottom.
I have also tried opening the MPLAB X project, but it looks like it doesn't delete them before regeneration, so it isn't generating new MPLAB X projects either.
" ---33fJ256GP710---"
"*** Created "executable": ..\../code_gen.cof"
''pic30-bin2hex ..\../code_gen.cof
"*** Converted code_gen.cof to code_gen.hex"
"*** MPLAB: file -> import, choose code_gen.hex. Configure -> Configuration Bits : Verify !"
" Download into the chip and run."
### Successful completion of Real-Time Workshop build procedure for model: code_gen
*** You could open project created and (re)compile it :
==> MPLAB 8: Within Matlab, right-click code_gen.mcp -> open outside Matlab.
==> MPLAB X: Start MPLAB X, then open the project folder C:\Users\Bryant\Projects\Autoboat\Code\basic_model\code_gen_dspic
The path '\circBuffer.c' does not exist
Warning : MPLAB project not created due to internal error
clib/conversions.c
clib/nmea0183.c
clib/nmea2000.c
clib/ecanSensors.c
clib/gps.c
clib/revo.c
clib/commProtocol.c
clib/uart1.c
clib/uart2.c
clib/DEE.c
clib/DEES.s
clib/misc.c
../../../ECAN_dspic/circBuffer.c
../../../ECAN_dspic/ecanFunctions.c
