Generated MPLAB projects don't allow debugging
Posted: Wed Mar 09, 2011 7:57 pm
The MPLAB projects that are generated on compilation don't set up the compilation within MPLAB to allow for debugging and stepping through the code. This is generally what I want to do when I go to use MPLAB. I've found that changing the following options allow for code step-through and variable watching:
Project->Build options->Project under the MPLAB LINK30 tab, Diagnostics category select "Generate map file"
Project->Build options->Project under the MPLAB C30 tab, General category select "Generate debugging information"
Would it make sense for these options to be set by default in the generated MPLAB projects?
