I use an Explorer16 development card and I tried to compile the example that you have provided with a PIC24Fj128GA010 and I received the following message.
On the other hand, I compiled it successfully with the dsPIc 33Fj256GP710 (also provided with the board). Have you already met any problem with the PIC24Fj128GA010.
Regards, amicalement
François
### Processing Template Makefile: C:\Users\François BATEMAN\Documents\Enseignement Recherche\Outils\install_dsPIC_R2007b_F_BATEMAN_Unlocked_SalonP_lsis\dspic\dspic_pic30_gcc.tmf
### Creating dsPIC_33f_Explorer16.mk from C:\Users\François BATEMAN\Documents\Enseignement Recherche\Outils\install_dsPIC_R2007b_F_BATEMAN_Unlocked_SalonP_lsis\dspic\dspic_pic30_gcc.tmf
### Building dsPIC_33f_Explorer16: .\dsPIC_33f_Explorer16.bat
C:\Users\Fran‡ois BATEMAN\Documents\Enseignement Recherche\Outils\install_dsPIC_R2007b_F_BATEMAN_Unlocked_SalonP_lsis\examples\dsPIC_33f_Explorer16_dspic\sources>set MATLAB=C:\Program Files\MATLAB\R2007b
C:\Users\Fran‡ois BATEMAN\Documents\Enseignement Recherche\Outils\install_dsPIC_R2007b_F_BATEMAN_Unlocked_SalonP_lsis\examples\dsPIC_33f_Explorer16_dspic\sources>"C:\PROGRA~1\MATLAB\R2007b\bin\win32\gmake" -f dsPIC_33f_Explorer16.mk GENERATE_REPORT=1 MULTI_INSTANCE_CODE=0 PORTABLE_WORDSIZES=0 GENERATE_ASAP2=0 TMW_EXTMODE_TESTING=0
C:\\PROGRA~1\\MICROC~1\\MPLABC~1\\bin\\pic30-gcc -c -mcpu=24fJ128GA010 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\Users\FRANOI~1\DOCUME~1\ENSEIG~1\Outils\INSTAL~2\examples\DSPIC_~2\sources -IC:\Users\FRANOI~1\DOCUME~1\ENSEIG~1\Outils\INSTAL~2\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc -I C:\PROGRA~1\MICROC~1\MPLABC~1\include dsPIC_33f_Explorer16_main.c
In file included from c:/progra~1/microc~1/mplabc~1/bin/bin/../../support/peripheral_24F/timer.h:35,
from dsPIC_33f_Explorer16_private.h:47,
c:/progra~1/microc~1/mplabc~1/bin/bin/../../support/peripheral_24F/GenericTypeDefs.h:53: error: syntax error before '(' token
bug while compiling the PIC24Fj128GA010
Re: bug while compiling the PIC24Fj128GA010
Hey François,
Thanks for that remark.
This error seems to be a file def problem from Microchip described quite a long time ago (see notes on release of blockset 13/02/2008 V0.96b here ).
The workaround is to edit the Microchip def file GenericTypeDefs.h usually placed at (win XP 32 bits) :
C:\Program Files\Microchip\MPLAB C30\support\peripheral_24F\GenericTypeDefs.h
and to comment line 64 as follow :
It should fix the problem. Let me know otherwise.
in file : GenericTypeDefs.h
64 // typedef enum _BOOL { FALSE = 0, TRUE } BOOL; /* Undefined size */
65 typedef enum _BIT { CLEAR = 0, SET } BIT;
Users browsing this forum: No registered users and 29 guests
