Error loading example
Using Embedded Target for MICROCHIP dsPIC V3.2b on a Windows XP3 machine and MATLAB R2006b:
the following is reported in the MATLAB command window:
Warning: Undefined function or method 'exist' for input arguments of type 'cell'.
> In C:\MATLAB\R2006b\toolbox\rtw\rtw\stf2target.p>stf2target at 61
In open at 146
In uiopen at 196
Warning: In instantiating linked block 'FlexBoard_Blinking_Led/Master' : Invalid setting in Master block (mask) 'Master' for parameter 'MCLR'.
> In C:\DSPIC_Lib\blocks\dsPIC_CalculusTimeStep_initMask.p>dsPIC_CalculusTimeStep_initMask at 6
In C:\DSPIC_Lib\blocks\dsPIC_UART_TX_Labview_Matlab_callback.p>dsPIC_UART_TX_Labview_Matlab_callback at 36
In open at 146
In uiopen at 196
Warning: Error evaluating 'LoadFcn' callback of Master block (mask) 'Master'. Error using ==> get_param
block_diagram does not have a parameter named 'GMAKE_PLACE'.
In open at 146
In uiopen at 196
Please advise.
In open at 146
In uiopen at 196
In open at 146
In uiopen at 196
In open at 146
In uiopen at 196
Please advise.
Re: Error loading example
it seems to be only warning that are cause by the fact that example were created with an order blockset version.
You just have to not pay attention to them. They should not appears once you'll save the model with your current blockset version.
as soon as you do not get an error (not a warning) , you can go on...
I have ignored the warnings and saved the example model file.
On double clicking the 'Master' block in the model, I get the following message in an 'Error' dialogue:
Error evaluating 'Open Fcn' callback of Master block (mask) 'Master.
Please advise.
Please advise.
I uploaded on the website new version (3.2c) of the blockset. Could you test with this last version and report if you still get the problem ?
I have installed V3.2c of the blockset for MATLAB R2007a (As this version does not support R2006b which I was using previously).
The following error(s) are reported when I load the example 'FlexBoard_Blinking_Led.mdl' :
Warning: Error using ==> getSTFInfo.p>getSTFInfo at 47
The following error occurred processing the System Target File '':
> In C:\MATLAB\R2007a\toolbox\rtw\rtw\stf2target.p>stf2target at 61
In open at 146
In uiopen at 196
Warning: GMAKE_PLACE not defined, check tlc target
> In C:\DSPIC_Lib\blocks\dsPIC_ConfigRTWOption.p>dsPIC_ConfigRTWOption at 45
In C:\DSPIC_Lib\blocks\dsPIC_MASTER_callback.p>dsPIC_MASTER_callback at 87
In open at 146
In uiopen at 196
Warning: Error evaluating 'LoadFcn' callback of Master block (mask) 'Master'. Error using ==> dsPIC_ConfigRTWOption at 359
In open at 146
In uiopen at 196
When I double click on the 'Master' block the following is displayed on an 'Error' message box:
Error evaluating 'OpenFcn' callback of Master block (mask) 'Master'.
Error using ==> <ahref="error:C:\DSPIC_Lib\blocks\dsPIC_ConfigRTWOption.p,359,1">dsPIC_ConfigRTWOption at 359</a>
When I check the selected System Target file it is 'dspic.tlc'.
Please advise.
In open at 146
In uiopen at 196
In open at 146
In uiopen at 196
In open at 146
In uiopen at 196
Please advise.
Dear Mike,
Sorry for the 1 month delay.
Did you still have the problem ?
I have no obvious idea right now.
Anyway, could you check that this problem with the latest version (please re-download the blockset that was just updating while you were writting your message (same date)...)
The problem is still as I have described
Sorry for complaining but I am totally suffering from the same problem with 2008b. I tried all the dspic related tlc target files but nothing solved. I was used to work on the previous versions which was succesful.mickpowell wrote:The problem is still as I have described
This is the main error when I press play:
Okay,
Let's see what's happening.
Can you compile the examples in the demo directory ?
did you tried to dbclick the yello block that configure and should solve automatically few problems ?
If you started a model from scratch, please upload it on the forum so I can have a look.
I really appreciate your code but for this version might have a problem. Lets see what we have.
I have R2009a at office and try all the steps again and had the same problem again..
MPLAB C Compiler for dsPIC v3.25 Standard-Eval Version 11/15/2010 3:43:44 PM 47769 KB installed first.
Download dsPIC Toolbox for Matlab R2009a (Matlab 32 and 64 bits) is installed by install_dsPIC_R2009a
Now I can see the toolbox in the list. It is ok!
Let's open the standard Flex example. >> FlexBoard_Blinking_Led.mdl double click >>
dbclick on yellow configure block, we observe the data on command screen... >> screen1 below
target is selected as below on RTW: >> screen2 below
when click to play in diagram: >>screen3 below
Very interested to find out a solution.
Thank you very much.
Onur Tarakçıoğlu
Installation of Real Time Embedded Coder for dsPIC is finished!
- YOU MUST INSTALL C30 and/or C32 COMPILER AVAILABLE ON THE MICROCHIP WEBSITE.
The C30 version included in the MPLAB distribution (v8.10) will
produce a error like "gld file not found"
- Checking that C30 PIC24 and/or dsPIC are installed on your system :
>>!pic30-lm
Microchip MPLAB C30 License Manager Version v3_25 (Build Date Oct 11 2010).
Copyright (c) 2008 Microchip Technology Inc. All rights reserved.
This demo-version license for MPLAB C for 16-bit devices,
has 60 days remaining after today.
- checking that C32 PIC32 is also installed on your system :
>>!pic32-gcc -v
'pic32-gcc'
- go to www.kerhuel.eu to check installation procedure
- Check installation : start the script CompileAllModels in the examples directory.
(copy-past the following)
cd examples
CompileAllModels
It will compile all the model present in
the example directory (for dsPIC and PIC24 and PIC32 ;
make sure you install compiler : for dsPIC and PIC24 and PIC32)
Warning: Could not find an exact (case-sensitive) match for 'ExecBatch'.
C:\Documents and Settings\Cat\Desktop\asdqwe\dspic\execBatch.p is a case-insensitive match and will be
used instead.
You can improve the performance of your code by using exact
name matches and we therefore recommend that you update your
usage accordingly. Alternatively, you can disable this warning using
warning('off','MATLAB:dispatcher:InexactCaseMatch').
This warning will become an error in future releases.
> In C:\Program Files\MATLAB\R2009a\toolbox\rtw\rtw\private\getSTFInfo.p>getSTFInfo at 73
In rtwprivate at 12
In stf4target at 34
In stf2target at 61
In open at 154
In uiopen at 196
Warning: The following error occurred processing the System Target File '':
> In stf2target at 61
In open at 154
In uiopen at 196
Warning: dsPICdrivers.mdl, line 49: block_diagram does not have a parameter named
'CovForceBlockReductionOff'.
In open at 154
In uiopen at 196
> In C:\Documents and Settings\Cat\Desktop\asdqwe\blocks\dsPIC_ConfigRTWOption.p>dsPIC_ConfigRTWOption at 45
In C:\Documents and Settings\Cat\Desktop\asdqwe\blocks\dsPIC_MASTER_callback.p>dsPIC_MASTER_callback at 87
In C:\Documents and Settings\Cat\Desktop\asdqwe\blocks\dsPIC_CalculusTimeStep_initMask.p>dsPIC_CalculusTimeStep_initMask at 6
In C:\Documents and Settings\Cat\Desktop\asdqwe\blocks\dsPIC_UART_Rx_Tx_Matlab_InitMask.p>dsPIC_UART_Rx_Tx_Matlab_InitMask at 9
In open at 154
In uiopen at 196
Warning: The *System Target File must be defined to dsPIC Real Time workshop (Simulation ==> Configuration
In open at 154
In uiopen at 196
Warning: Error evaluating 'LoadFcn' callback of Master block (mask) 'Master'. The *System Target File must
In open at 154
In uiopen at 196
In open at 154
In uiopen at 196
In open at 154
In uiopen at 196
In open at 154
In uiopen at 196
In open at 154
In uiopen at 196
Onur Tarakçıoğlu
Hi Onur,
Thanks for your report. Please upload directly your image on the forum, it's much more easier to see and open them than through rapidShare.
Anyway, at first, I could not reproduced the bug. However, I saw that you have the Microchp blockset installed. Thus I installed it on my system (v2.10) and I could not compild my example (FlexBoard_Blinking_Led.mdl) anymore. Thus, I re-installed my blockset and it worked properly again. I guess that booth blockest are calling same function name, and the latest blockset installed get the priority in the matlab Path.
Unfortunately, the problem was not exactly the same as you get. Anyway, there is clearly an incompatibility between booth blockset (I will try to understand what's happening !)
Could you tell me if all the model in the example directory does not compile from your side ? (just launch CompileAllModels.m script)
Thank you for your keen interest. Pictures are ok. I just started the CompileAllModels.m and the command window is as given below. All the other models give the same error about target file.
I reinstall your library. But had the same error. I gonna uninstall the Microchip library somehow...
> In CompileAllModels at 10
C:\Documents and Settings\Cat\Desktop\asdqwe\dspic\execBatch.p is a case-insensitive match and will be used
instead.
In rtwprivate at 12
In stf4target at 34
In stf2target at 61
In CompileAllModels at 12
> In stf2target at 61
In C:\Documents and Settings\Cat\Desktop\asdqwe\blocks\dsPIC_ConfigureModelFordsPICTarget.p>dsPIC_ConfigureModelFordsPICTarget at 52
In CompileAllModels at 13
??? Error using ==> dsPIC_ConfigureModelFordsPICTarget at 59
Error using ==> dsPIC_ConfigRTWOption at 357
Error in ==> CompileAllModels at 13
dsPIC_ConfigureModelFordsPICTarget();
Hi Onur and mickpowell
Thanks Onur for uploading your illustration on the forum.
From your message, i appears that there may be a bug in the blockset for some computer configuration.
As I can't reproduce it, I would ask for your help.
Could you please upload the file testing.p, copy it in the example directory of the blockest.
The experiment is fairly simple : could you first open one of the model (FlexBoard_Blinking_Led.mdl) and then, launch the script typing testing. (this is a script for matlab 2009a)
Please launch the script at least twice and report all message that may appears.
"testing.p" is a script very similar to dsPIC_ConfigRTWOption.p from the blockset. This versiou should give me some more insight into the error with from the error message...
The experiment is fairly simple : could you first open one of the model (FlexBoard_Blinking_Led.mdl) and then, launch the script typing >> testing at the matlab prompt. (this is a script for matlab 2009a)
Please launch the script at least twice and report all message that will appears.
- testing.p
- script to test after opening a simulink model file using LK dspic blockset.
- (2.28 KiB) Downloaded 668 times
Sorry for late response. I ran the testing but a primative error arrises.
Hope that this helps.
After that I have removed the Microchip lib and install your lib again. Still the problem goes on...
thx
onur
instead.
In rtwprivate at 12
In stf4target at 34
In stf2target at 61
In open at 154
In uiopen at 196
> In stf2target at 61
In open at 154
In uiopen at 196
In open at 154
In uiopen at 196
In open at 154
In uiopen at 196
In open at 154
In uiopen at 196
In open at 154
In uiopen at 196
In open at 154
In uiopen at 196
In open at 154
In uiopen at 196
In open at 154
In uiopen at 196
In open at 154
In uiopen at 196
>> testing.p
> In C:\Documents and Settings\Cat\Desktop\asdqwe\examples\testing.p>testing at 45
??? Error using ==> testing at 81
block_diagram does not have a parameter named 'LDPICTYPE'.
>> testing.p
REMOVING Target for Microchip(TM) dsPIC 2.10
Target for Microchip(TM) dsPIC 2.10 is Installed and ready to use.
INSTALLATION RTWdsPIC
Reading the archiv
Checksum test passed (18B2AABAED767)
RTWdsPIC version none
RTWdsPIC time stamp 22-Nov-2010 01:00:55
Importing the archiv 100% |******************************|
Toolbox folder is C:\Documents and Settings\Cat\Desktop\asdqwe
addpath 'C:\Documents and Settings\Cat\Desktop\asdqwe'
Creating Readme.html
Creating blocks\EmptySFunction.mexw32
Creating blocks\EmptySFunction.mexw64
Creating blocks\EmptySFunction.tlc
Creating blocks\GetDsPICParam.p
Creating blocks\RS232_analyzBloc.p
Creating blocks\Set_DialogBoxMask.p
Creating blocks\combinatoire.p
Creating blocks\dsPIC_ADC.mexw32
Creating blocks\dsPIC_ADC.mexw64
Creating blocks\dsPIC_ADC.tlc
Creating blocks\dsPIC_ADC_callback.p
Creating blocks\dsPIC_ADC_callback_InitMask.p
Creating blocks\dsPIC_ADC_param2mex.p
Creating blocks\dsPIC_CAN_Config.mexw32
Creating blocks\dsPIC_CAN_Config.mexw64
Creating blocks\dsPIC_CAN_Config.tlc
Creating blocks\dsPIC_CAN_Config_callback.p
Creating blocks\dsPIC_CAN_Receive.mexw32
Creating blocks\dsPIC_CAN_Receive.mexw64
Creating blocks\dsPIC_CAN_Receive.tlc
Creating blocks\dsPIC_CAN_Receive_callback.p
Creating blocks\dsPIC_CAN_Transmit.mexw32
Creating blocks\dsPIC_CAN_Transmit.mexw64
Creating blocks\dsPIC_CAN_Transmit.tlc
Creating blocks\dsPIC_CAN_Transmit_callback.p
Creating blocks\dsPIC_C_function_Call.mexw32
Creating blocks\dsPIC_C_function_Call.mexw64
Creating blocks\dsPIC_C_function_Call.tlc
Creating blocks\dsPIC_C_function_Call_callback.p
Creating blocks\dsPIC_CalculusTimeStep.mexw32
Creating blocks\dsPIC_CalculusTimeStep.mexw64
Creating blocks\dsPIC_CalculusTimeStep.tlc
Creating blocks\dsPIC_CalculusTimeStep_initMask.p
Creating blocks\dsPIC_CheckParamSimulation.p
Creating blocks\dsPIC_Chronograph.mexw32
Creating blocks\dsPIC_Chronograph.mexw64
Creating blocks\dsPIC_Chronograph.tlc
Creating blocks\dsPIC_Chronograph_Callback.p
Creating blocks\dsPIC_Compile.p
Creating blocks\dsPIC_ConfigClock32f.p
Creating blocks\dsPIC_ConfigClock33f.p
Creating blocks\dsPIC_ConfigRTWOption.p
Creating blocks\dsPIC_ConfigureModelFordsPICTarget.p
Creating blocks\dsPIC_Digital_Input.mexw32
Creating blocks\dsPIC_Digital_Input.mexw64
Creating blocks\dsPIC_Digital_Input.tlc
Creating blocks\dsPIC_Digital_Input_callback.p
Creating blocks\dsPIC_Digital_OutputRead.mexw32
Creating blocks\dsPIC_Digital_OutputRead.mexw64
Creating blocks\dsPIC_Digital_OutputRead.tlc
Creating blocks\dsPIC_Digital_OutputRead_callback.p
Creating blocks\dsPIC_Digital_OutputWrite.mexw32
Creating blocks\dsPIC_Digital_OutputWrite.mexw64
Creating blocks\dsPIC_Digital_OutputWrite.tlc
Creating blocks\dsPIC_Digital_OutputWrite_callback.p
Creating blocks\dsPIC_ECAN_Config.mexw32
Creating blocks\dsPIC_ECAN_Config.mexw64
Creating blocks\dsPIC_ECAN_Config.tlc
Creating blocks\dsPIC_EXT_INT_PWM_callback_InitMask.p
Creating blocks\dsPIC_EXT_INT_PWM_param2mex.p
Creating blocks\dsPIC_Ext_Interrupt_PWM.mexw32
Creating blocks\dsPIC_Ext_Interrupt_PWM.mexw64
Creating blocks\dsPIC_Ext_Interrupt_PWM.tlc
Creating blocks\dsPIC_Get_Dialog_PopUp_Param.p
Creating blocks\dsPIC_Get_Dialog_PromptString.p
Creating blocks\dsPIC_I2C_Master.mexw32
Creating blocks\dsPIC_I2C_Master.mexw64
Creating blocks\dsPIC_I2C_Master.tlc
Creating blocks\dsPIC_I2C_Master_callback.p
Creating blocks\dsPIC_MASTER.mexw32
Creating blocks\dsPIC_MASTER.mexw64
Creating blocks\dsPIC_MASTER.tlc
Creating blocks\dsPIC_MASTER_callback.p
Creating blocks\dsPIC_MASTER_callback_InitMask.p
Creating blocks\dsPIC_Nop.mexw32
Creating blocks\dsPIC_Nop.mexw64
Creating blocks\dsPIC_Nop.tlc
Creating blocks\dsPIC_PIN_Mapping.mexw32
Creating blocks\dsPIC_PIN_Mapping.mexw64
Creating blocks\dsPIC_PIN_Mapping.tlc
Creating blocks\dsPIC_PIN_Mapping_Callback.p
Creating blocks\dsPIC_PWM_CN.mexw32
Creating blocks\dsPIC_PWM_CN.mexw64
Creating blocks\dsPIC_PWM_CN.tlc
Creating blocks\dsPIC_PWM_CN_CheckDiag.p
Creating blocks\dsPIC_PWM_CN_callback.p
Creating blocks\dsPIC_PWM_IC.mexw32
Creating blocks\dsPIC_PWM_IC.mexw64
Creating blocks\dsPIC_PWM_IC.tlc
Creating blocks\dsPIC_PWM_IC_CheckDiag.p
Creating blocks\dsPIC_PWM_IC_callback.p
Creating blocks\dsPIC_PWM_Motor_callback.p
Creating blocks\dsPIC_PWM_OC.mexw32
Creating blocks\dsPIC_PWM_OC.mexw64
Creating blocks\dsPIC_PWM_OC.tlc
Creating blocks\dsPIC_PWM_OC_CheckDiag.p
Creating blocks\dsPIC_PWM_OC_HW.mexw32
Creating blocks\dsPIC_PWM_OC_HW.mexw64
Creating blocks\dsPIC_PWM_OC_HW.tlc
Creating blocks\dsPIC_PWM_OC_HW_CheckDiag.p
Creating blocks\dsPIC_PWM_OC_HW_callback.p
Creating blocks\dsPIC_PWM_OC_HW_callback_InitMask.p
Creating blocks\dsPIC_PWM_OC_callback.p
Creating blocks\dsPIC_PWM_OC_callback_InitMask.p
Creating blocks\dsPIC_PWM_motor.mexw32
Creating blocks\dsPIC_PWM_motor.mexw64
Creating blocks\dsPIC_PWM_motor.tlc
Creating blocks\dsPIC_PWM_motor_callback_InitMask.p
Creating blocks\dsPIC_PortSetting.p
Creating blocks\dsPIC_Reset.mexw32
Creating blocks\dsPIC_Reset.mexw64
Creating blocks\dsPIC_Reset.tlc
Creating blocks\dsPIC_SPI_IO.mexw32
Creating blocks\dsPIC_SPI_IO.mexw64
Creating blocks\dsPIC_SPI_IO.tlc
Creating blocks\dsPIC_SPI_IO_Interrupt.mexw32
Creating blocks\dsPIC_SPI_IO_Interrupt.mexw64
Creating blocks\dsPIC_SPI_IO_Interrupt.tlc
Creating blocks\dsPIC_SPI_IO_Interrupt_Callback.p
Creating blocks\dsPIC_SPI_IO_callback.p
Creating blocks\dsPIC_SPI_IO_param2mex.p
Creating blocks\dsPIC_SPI_config.mexw32
Creating blocks\dsPIC_SPI_config.mexw64
Creating blocks\dsPIC_SPI_config.tlc
Creating blocks\dsPIC_SPI_config_callback.p
Creating blocks\dsPIC_SPI_config_param2mex.p
Creating blocks\dsPIC_SerialReadSimulink.p
Creating blocks\dsPIC_Set_Dialog_PopUp_Param.p
Creating blocks\dsPIC_Set_Dialog_PromptString.p
Creating blocks\dsPIC_TimerSetting.p
Creating blocks\dsPIC_UART_RX.mexw32
Creating blocks\dsPIC_UART_RX.mexw64
Creating blocks\dsPIC_UART_RX.tlc
Creating blocks\dsPIC_UART_RX_callback.p
Creating blocks\dsPIC_UART_RX_param2mex.p
Creating blocks\dsPIC_UART_Rx_Tx_Matlab_InitMask.p
Creating blocks\dsPIC_UART_TX.mexw32
Creating blocks\dsPIC_UART_TX.mexw64
Creating blocks\dsPIC_UART_TX.tlc
Creating blocks\dsPIC_UART_TX_Labview_Matlab.mexw32
Creating blocks\dsPIC_UART_TX_Labview_Matlab.mexw64
Creating blocks\dsPIC_UART_TX_Labview_Matlab.tlc
Creating blocks\dsPIC_UART_TX_Labview_Matlab_callback.p
Creating blocks\dsPIC_UART_TX_callback.p
Creating blocks\dsPIC_UART_callback_InitMask.p
Creating blocks\dsPIC_UART_config.mexw32
Creating blocks\dsPIC_UART_config.mexw64
Creating blocks\dsPIC_UART_config.tlc
Creating blocks\dsPIC_UART_config_callback.p
Creating blocks\dsPIC_code_template.cgt
Creating blocks\dsPIC_main.tlc
Creating blocks\dsPIC_mrmain.tlc
Creating blocks\dsPIC_srmain.tlc
Creating blocks\dsPICdrivers.mdl
Creating blocks\dspicListe.mat
Creating blocks\fOrderingInOut.p
Creating blocks\fPin.p
Creating blocks\fPortRef.p
Creating blocks\pad.p
Creating blocks\padr.p
Creating blocks\rs232gui.fig
Creating blocks\rs232gui.p
Creating blocks\slblocks.m
Creating dspic\Contents.m
Creating dspic\Contents.p
Creating dspic\Contents.txt
Creating dspic\dsPIC_CreateMPLAB.p
Creating dspic\dspic.tlc
Creating dspic\dspic_pic30_gcc.tmf
Creating dspic\dspic_select_callback_handler.p
Creating dspic\execBatch.p
Creating dspic\getPath.bat
Creating dspic\getProgramFilesPath.bat
Creating dspic\getProgramFilesx86Path.bat
Creating dspic\info.xml
Creating dspic\make_CreateMPLAB.p
Creating dspic\pic32.tlc
Creating dspic\pic32_gcc.tmf
Creating dspic\pic32_select_callback_handler.p
Creating dspic\setup_for_lcc.p
Creating dspic\sl_customization.p
Creating examples\CompileAllModels.m
Creating examples\Data_Login_Matlab.mdl
Creating examples\FlexBoard_Blinking_Led.mdl
Creating examples\Servo_ADC.mdl
Creating examples\Servo_Sinus.mdl
Creating examples\dsPIC_32MX460F512L_Explorer16_HyperSampling.mdl
Creating examples\dsPIC_33f_Explorer16.mdl
Update path...
Embedded Coder for dsPIC V3.3a(22-Nov-2010) for Matlab R2009a.
Licence Accorded to Demonstration Version
RTWdsPIC@kerhuel.eu
Author : Lubin KERHUEL
WEBSITE : http://www.kerhuel.eu/wiki
SIRENE : 503 920 456
SIRET : 503 920 456 00012
Facturation to : Demo
Demo
Lubin KERHUEL
1, rue Alfred Fredet
38100 Grenoble
FRANCE
Check updates and new informations at : www.kerhuel.eu
>>!pic30-lm
has 56 days remaining after today.
>>!pic32-gcc -v
'pic32-gcc' i‡ ya da dŸ komut, ‡alŸtrlabilir
program ya da toplu iŸ dosyas olarak tannmyor.
cd examples
CompileAllModels
used instead.
In rtwprivate at 12
In stf4target at 34
In stf2target at 61
In open at 154
In uiopen at 196
> In stf2target at 61
In open at 154
In uiopen at 196
In open at 154
In uiopen at 196
In open at 154
In uiopen at 196
In open at 154
In uiopen at 196
In open at 154
In uiopen at 196
Warning: In instantiating linked block 'Servo_ADC/ADC Input' : Invalid setting in dsPIC : ADC10 block
(mask) 'ADC Input' for parameter 'OutFormatBitspopup'.
> In C:\Documents and Settings\Cat\Desktop\asdqwe\blocks\dsPIC_PWM_OC_callback.p>dsPIC_PWM_OC_callback at 94
In open at 154
In uiopen at 196
In C:\Documents and Settings\Cat\Desktop\asdqwe\blocks\dsPIC_ADC_callback_InitMask.p>dsPIC_ADC_callback_InitMask at 9
In open at 154
In uiopen at 196
In open at 154
In uiopen at 196
In open at 154
In uiopen at 196
onur
Hi Onur, Hi mickpowell,
Thanks for all your remarks that makes me go forward.
I think I find out the problem. Please give a try to the latest blockset version (3.3b) and let me know if problem is solved.
I want to congr. you since everything is ok with v3.3b!
See the code below:
Thank you very much!!!
See the code below:
new GMAKE path : C:\PROGRA~1\MATLAB\R2009a\bin\win32\gmake
Linker is now called through pic30-gcc as it did not worked anymore using pic30-ar. Linker options have been updated consequently !
file not found : C:\PROGRA~1\MICROC~1\MPLABC~2\support\dsPIC33F\gld\p33fJ256MC710.gld
--> corrected : find in --script=C:\PROGRA~1\MICROC~1\mplabc30\v3.25\support\dsPIC33F\gld\p33fJ256MC710.gld
file not found : C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libpic30-coff.a
--> corrected : find in C:\PROGRA~1\MICROC~1\mplabc30\v3.25\lib\libpic30-coff.a
file not found : C:\PROGRA~1\MICROC~1\MPLABC~2\lib\dsPIC33F\libp33fJ256MC710-coff.a
--> corrected : find in C:\PROGRA~1\MICROC~1\mplabc30\v3.25\lib\dsPIC33F\libp33fJ256MC710-coff.a
file not found : C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libc-coff.a
--> corrected : find in C:\PROGRA~1\MICROC~1\mplabc30\v3.25\lib\libc-coff.a
file not found : C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libm-coff.a
--> corrected : find in C:\PROGRA~1\MICROC~1\mplabc30\v3.25\lib\libm-coff.a
PNumber of I/O PINs used : 3
TModel configured...
PPTPNumber of I/O PINs used : 3
TTPTPTTPTPTPTTPTPTWarning: Source 'FlexBoard_Blinking_Led/Calculus Time Step' specifies that its sample time (-1) is
back-inherited. You should explicitly specify the sample time of sources. You can disable this diagnostic by
setting the 'Source block specifies -1 sample time' diagnostic to 'none' in the Sample Time group on the
Diagnostics pane of the Configuration Parameters dialog box.
Warning: The block 'FlexBoard_Blinking_Led/Data Store Read4' is reading from the data store
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.
Warning: The block 'FlexBoard_Blinking_Led/Data Store Read1' is reading from the data store
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.
Warning: The block 'FlexBoard_Blinking_Led/Data Store Read2' is reading from the data store
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.01.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.01.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.01.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.02.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.02.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.02.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.03.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.03.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.03.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.04.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.04.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.04.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.05.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.05.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.05.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.06.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.06.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.06.
0.07000000000000001.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.08.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.08.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.08.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.09.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.09.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.09.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.1.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.1.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.1.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.11.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.11.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.11.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.12.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.12.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.12.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.13.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.13.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.13.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.14.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.14.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.14.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.15.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.15.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.15.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.16.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.16.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.16.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.17.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.17.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.17.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.18.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.18.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.18.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.19.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.19.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.19.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.2.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.2.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.2.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.21.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.21.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.21.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.22.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.22.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.22.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.23.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.23.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.23.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.24.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.24.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.24.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.25.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.25.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.25.
Warning: Overflow occurred. This originated from 'FlexBoard_Blinking_Led/0.5Hz/Increment Real World/FixPt
Sum1'.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.26.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.26.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.26.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.27.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.27.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.27.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.28.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.28.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.28.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.29.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.29.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.29.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.3.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.3.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.3.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.31.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.31.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.31.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.32.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.32.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.32.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.33.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.33.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.33.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.34.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.34.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.34.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.35.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.35.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.35.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.36.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.36.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.36.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.37.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.37.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.37.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.38.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.38.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.38.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.39.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.39.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.39.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.4.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.4.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.4.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.41.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.41.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.41.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.42.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.42.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.42.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.43.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.43.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.43.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.44.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.44.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.44.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.45.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.45.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.45.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.46.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.46.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.46.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.47.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.47.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.47.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.48.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.48.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.48.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.49.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.49.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.49.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.5.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.5.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.5.
Warning: Overflow occurred. This originated from 'FlexBoard_Blinking_Led/Switch'.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.51.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.51.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.51.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.52.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.52.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.52.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.53.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.53.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.53.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.54.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.54.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.54.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.55.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.55.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.55.
0.5600000000000001.
0.5600000000000001.
0.5600000000000001.
0.5700000000000001.
0.5700000000000001.
0.5700000000000001.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.58.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.58.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.58.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.59.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.59.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.59.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.6.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.6.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.6.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.61.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.61.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.61.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.62.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.62.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.62.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.63.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.63.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.63.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.64.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.64.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.64.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.65.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.65.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.65.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.66.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.66.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.66.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.67.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.67.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.67.
0.6800000000000001.
0.6800000000000001.
0.6800000000000001.
0.6900000000000001.
0.6900000000000001.
0.6900000000000001.
0.7000000000000001.
0.7000000000000001.
0.7000000000000001.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.71.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.71.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.71.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.72.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.72.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.72.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.73.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.73.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.73.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.74.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.74.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.74.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.75.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.75.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.75.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.76.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.76.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.76.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.77.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.77.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.77.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.78.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.78.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.78.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.79.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.79.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.79.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.8.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.8.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.8.
0.8100000000000001.
0.8100000000000001.
0.8100000000000001.
0.8200000000000001.
0.8200000000000001.
0.8200000000000001.
0.8300000000000001.
0.8300000000000001.
0.8300000000000001.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.84.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.84.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.84.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.85.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.85.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.85.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.86.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.86.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.86.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.87.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.87.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.87.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.88.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.88.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.88.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.89.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.89.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.89.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.9.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.9.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.9.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.91.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.91.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.91.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.92.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.92.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.92.
0.9300000000000001.
0.9300000000000001.
0.9300000000000001.
0.9400000000000001.
0.9400000000000001.
0.9400000000000001.
0.9500000000000001.
0.9500000000000001.
0.9500000000000001.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.96.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.96.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.96.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.97.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.97.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.97.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.98.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.98.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.98.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 0.99.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 0.99.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 0.99.
'FlexBoard_Blinking_Led/Data Store Memory3' before any blocks have written to this memory at time 1.
'FlexBoard_Blinking_Led/Data Store Memory2' before any blocks have written to this memory at time 1.
'FlexBoard_Blinking_Led/Data Store Memory1' before any blocks have written to this memory at time 1.
Thx Onur for precious help and for your feedback !
Users browsing this forum: No registered users and 129 guests
