possible bug using 2 ADC - solved
MHuy
Post by MHuy » Mon Apr 06, 2009 10:31 am
I try to compile this model but it doesn't work.
It writes the following message in the command window.
dsPIC_DMA_Buffers.c:3: error: syntax error before 'ADCBuffChannelDMA'
dsPIC_DMA_Buffers.c:3: warning: data definition has no type or storage class
gmake: *** [dsPIC_DMA_Buffers.o] Error 255
In the file "dsPIC_DMA_Buffers.c", there is no include of "test_ADC_private.h" (NameOfTheModel_private.h) where the variable ADCBuffChannelDMA as the type extern.
//dsPIC_DMA_Buffers.c
#include "p33fxxxx.h"
volatile uint16_T ADCBuffChannelDMA[(2)] __attribute__((space(dma),aligned(256)));
//test_ADC_private.h
extern volatile uint16_T ADCBuffChannelDMA[(2)] __attribute__((space(dma),aligned(256)));
Does the compilation error come from that problem? or do you have an other idea?
Thanks for your help!
Michael
PS : I use the dsPIC33FJ128GP802 chip.
test_ADC.mdl
(29.13 KiB) Downloaded 1017 times
Re: possible bug using 2 ADC
Post by LubinKerhuel » Tue Apr 07, 2009 9:32 am
Which blockset version are you working with ? (0.99c ?)
MHuy
Post by MHuy » Tue Apr 07, 2009 10:32 am
I use the 0.99b, is it working with the 0.99c?
Post by LubinKerhuel » Tue Apr 07, 2009 11:54 pm
I corrected a bug similar to this one just before publishing the 0.99c version.
I thought that this bug was not present yet in the 0.99b, but it may be the same.
Anyway, could you test your model using the 0.99c version ?
(Note that the 0.99c version on the website is depicted as 0.99b+ at the matlab command "ver". That is the last bug I found ! not really important...)
Let me know if you still have this bug...
MHuy
Post by MHuy » Thu Apr 09, 2009 9:56 am
There is no more bug with the v0.99c!
Thanks for your help Lubin
Michael
