Two UARTs in a single model
bmairs
Post by bmairs » Sat Feb 26, 2011 10:36 pm
I'm trying to use the following model to test my hardware setup for using both UARTS. Unfortunately I get an error stating "Error using ==> dsPIC_UART_RX_callback at 76\nProblem".
I've attached the model I'm using for you.
UART.mdl
(28.54 KiB) Downloaded 1051 times
Re: Two UARTs in a single model
Post by LubinKerhuel » Sat Feb 26, 2011 11:52 pm
Thanks for repporting the problem.
Problem is now solved and will be available in next blockset version (following v3.4b)
ismaeelbit
Post by ismaeelbit » Fri May 27, 2011 1:00 pm
Hi Lubin, I am experienceing the same problem using two UART on pic24fj128ga010. The version of the blockset I have is 3.4bc. is this the one you are reffering to or I need to get the update?
Addition error mesage is "index exceed matrix dimension"
