Hi Lubin, I already told you but i write it there to give the solution to everyone
If you want to use the internal quartz with a dspic33fj128gp802/804 (maybe you will have the same problem with others micro-controllers but i tested these two), the PLL value is not taken into account which prevents you from choosing the number of instructions you want.
The solution i found is to go into the main source file created when you compile and change _FOSCSEL( FNOSC_FRC & IESO_OFF & 0xFFFF ) by _FOSCSEL( FNOSC_FRCPLL & IESO_OFF & 0xFFFF ).
All the others registers to select the different prescalers are correct so you should have the right number of MIPS.
Internal Quartz and PLL
