Question about Filter
micman2
Post by micman2 » Fri Feb 15, 2008 6:15 pm
I saw two examples that implement filters, I noticed the speed with which you can implement filters in a dspic.
But I have a question:
How has been calculated Band pass filter?
Re: Question about Filter
Post by LubinKerhuel » Mon Feb 18, 2008 11:21 pm
Low pass filter with a cut off frequency at 1 Hz :
1Hz means 2*pi rad/s which is approximatively 6 rad/s.
matlab code :
>> Filter_1Hz = tf([6],[1 6])
Transfer function:
  6
s + 6
>> bode(Filter_1Hz)
You will get :
We have a 45° phase and a -3db cut off at 6 rad/s which is approximatively 1Hz.
6 should be replace by 2*pi so as to get a precise 1Hz low pass filter.
If you are note familiar with theses math, have a look on the Laplace transform.
The filter is then discretized for a sampling rate of 200Hz using the c2d function with the tustin method.
chukhivuitinh
Post by chukhivuitinh » Wed Apr 23, 2008 12:26 pm
can simu kalman filter ????
Post by LubinKerhuel » Thu Apr 24, 2008 11:17 pm
I will have a look on kalman filter to estimate the gyro bias. But I could not give a date when I will do it.
You could do it anyway !
