Data Logging to LabVIEW
Masaki
Post by Masaki » Wed Mar 12, 2008 3:12 am
TX_Labview_MATLAB block is a powerful tool to data logging.
But, thinking about the software integration, I would also like to data log to LabVIEW.
So my questions here are:
1) Is there any LabVIEW code which can interface to the TX_Labview_MATLAB block?
2) If there isn't such code left, is it possible to know the data format?
I seem to find it in the following URL, but I cannot read french unfortunetely.
http://lubink.free.fr/projelectro/Proto ... ew_FR.html
Masaki
Masaki
Re: Data Logging to LabVIEW
Post by Masaki » Wed Apr 30, 2008 7:04 am
Anyway, I attach old labview files. I provide it "in its actual state".
I have not installed labview on my computer right now.
Based on your LabVIEW program, I have made my interfacing program.
At the same time, I've tried to figure our your French home page, where you wrote about the
protocole. I understand that all data from "TX_LabVIEW_MATLAB" block have following headers:
bits 7-4: Number of the channel (0 to 15)
bits 3-2: type of data corresponding to the number of bytes composing the data (1 to 4)
bits 1-0: signature of the byte controls = "01"
Is this understanding correct?
If it's so, my next question is what happens if data happen to have confusing values
resembling to header format. For example, in binary:
00000101 00010101 00020101 00000101 00010101 01000101 .....
I wrote these bytes in terms of int16 data from channel 0.
But they can also be interpreted as int 16 data from channel 1.
How does your algorithm in "interface Tx-MATLAB" block distinguish the two cases?
Masaki
Post by LubinKerhuel » Wed Apr 30, 2008 11:34 pm
Hi Masaki,
Masaki wrote:bits 7-4: Number of the channel (0 to 15)
Correct !
TX_LabVIEW_MATLAB protocol
Masaki wrote:If it's so, my next question is what happens if data happen to have confusing values
It is not possible to distinguish here between the two possibilities on this example.
However, in most case, data will not always have their two lowest bytes set to 01. If few data do not finish by 01, the labview algorithm will converge after a few data to the correct solution.
If labview is started before the dsPIC started to send data, there will be no error. Errors may occur only when you hot plug the serial line or start labview while dsPIC is sending data.
Note that the matlab script is even more powerful that the labview algorithm because it extract the solution which is the best, considering the whole data frame received at time T. In this way, it is optimal because it use all the information available. The labview algorithm is suboptimal because it analyses the data frame byte after byte in chronological order and takes on the fly decisions.
(dataframe is the set of data read from the COM port. It may contain 0 to several hundred or thousand of bytes)
The labview algorithm that Masaki is using will be published soon on the website.
Users browsing this forum: No registered users and 29 guests
