DSPIC30F1010/DSPIC30F2020 support
I have MPLAB C30 compiler v3.02 and Matlab R2007a
I am using DSPIC30F1010/DSPIC30F2020 Switch Mode Power Supply (SMPS) . Please tell me from where can I get models for this device.
If you have then please send me.
Re: DSPIC30F1010/DSPIC30F2020 and 30f2023 support
Hi Narongchai,
The dsPIC 30f1010, 30f2020 and 30f2023 are quite different from others dsPIC30f family.
Some modification must be done on the blockset to support these chips.
So, If many users ask for the support of theses dsPIC, I will manage to support them (time consuming work).
Users interested by theses dsPIC, please leave messages here.
Re: DSPIC30F1010/DSPIC30F2020 support
I would also be very interested in support for these 30F2020 support as well.
I would also be very interested in support for these 30F2020 support as well, since I have to control a chopper with such a component via Simulink for a project in my engineering school.
Regards,
Mathieu
Regards,
Mathieu
Triangular Modulation
Can you tell me about PWM unit of dsPIC 30F2020 SMPS development board? I wanted to use triangular modulation in that but i could not find anything such like that in it?
I did not used this borad yet ; Couldn't help
I would also be interested in dSPIC30F2020 support or even better 30f2023 support for SMPS simulation.
Is there any possibility to use alternative models until then?
Support for theses chip were started but is now stopped as it seems to be quite a lots of differences.
Few students from Supelec (french engineering school) attempted to use it, but I did not get news from them.
Users browsing this forum: No registered users and 105 guests
