'CompileAllModels' Error
Posted: Sun Jun 06, 2010 8:37 pm
I've just installed MPLAB C32 compiler and your latest (3.2b) blockset for Matlab 2009a. It seems to install correctly although I have problems as soon as I run the suggested check using the 'CompileAllModels.m' script. The output is as follows:
I get a similar problem when trying to open block such as 'Configure Model' and 'Master' with reference to the GMAKE_PLACE fault.
It's probably a rookie mistake but I'd really appreciate your help as I think the blockset is going to be hugely useful!
Many thanks!
Ed
>> CompileAllModels.m
> In CompileAllModels at 11
Warning: The following error occurred processing the
System Target File '':
Undefined function or variable "myData".
> In stf2target at 61
In C:\dsPIC_Toolbox\blocks\dsPIC_ConfigureModelFordsPICTarget.p>dsPIC_ConfigureModelFordsPICTarget at 42
In CompileAllModels at 14
??? Error using ==> dsPIC_ConfigureModelFordsPICTarget
at 51
Error using ==> dsPIC_ConfigRTWOption at 11
block_diagram does not have a parameter named
'GMAKE_PLACE'.
Error in ==> CompileAllModels at 14
dsPIC_ConfigureModelFordsPICTarget();
Many thanks!
Ed
