edlaurence
Post
by edlaurence » Sun Jun 06, 2010 8:37 pm
I've just installed MPLAB C32 compiler and your latest (3.2b) blockset for Matlab 2009a. It seems to install correctly although I have problems as soon as I run the suggested check using the 'CompileAllModels.m' script. The output is as follows:
>> CompileAllModels.m
> In CompileAllModels at 11
Warning: The following error occurred processing the
System Target File '':
Undefined function or variable "myData".
> In stf2target at 61
In C:\dsPIC_Toolbox\blocks\dsPIC_ConfigureModelFordsPICTarget.p>dsPIC_ConfigureModelFordsPICTarget at 42
In CompileAllModels at 14
??? Error using ==> dsPIC_ConfigureModelFordsPICTarget
at 51
Error using ==> dsPIC_ConfigRTWOption at 11
block_diagram does not have a parameter named
'GMAKE_PLACE'.
Error in ==> CompileAllModels at 14
dsPIC_ConfigureModelFordsPICTarget();
I get a similar problem when trying to open block such as 'Configure Model' and 'Master' with reference to the GMAKE_PLACE fault.
It's probably a rookie mistake but I'd really appreciate your help as I think the blockset is going to be hugely useful!
Many thanks!
Ed
edlaurence
Post
by edlaurence » Mon Jun 07, 2010 11:59 am
Hi again,
Looks like I've fixed the problem by installing C30 as well as C32. It makes sense that this would cause issues when running the 'CompileAllModels' script but didn't expect GMAKE_PLACE errors when just trying to add blocks and configure for PIC32...?
Cheers!
Ed
Post
by LubinKerhuel » Tue Jun 08, 2010 6:51 pm
Anyway, thanks for reporting it !
alby.divy
Post
by alby.divy » Tue Jun 29, 2010 11:47 am
I've the same error! I don't understand how you have debugged it!
Can you help me?
Alb
edlaurence
Post
by edlaurence » Sun Jul 11, 2010 8:44 pm
Hi Alb,
Just make sure you have the correct MPLAB compiler installed for your application. If you plan to run the 'CompileAllModels' script please be aware that you're compiling models for a few different targets which in themselves require different compilers (either C30 or C32). They can both be downloaded from the Microchip website.
Hope that helps,
Ed
Users browsing this forum: No registered users and 109 guests
