How to change directory?
micman2
Post by micman2 » Wed Feb 13, 2008 9:30 am
I'm new user, How to change directory C:\Program File\Microchip\MPLAB C30 in C:\Programmi\Microchip\MPLAB C30 ?
Michele
Re: How to change directory?
Post by LubinKerhuel » Wed Feb 13, 2008 1:13 pm
Hi Michele,
a similar problem with its solution are described here : viewtopic.php?f=5&t=73#p152
Adapt and try the solution proposed.
adaptation would be ==> rtw_alt_pathname('C:\Programmi\Microchip\MPLAB C30')
If you still have the problem, please let us know.
micman2
Post by micman2 » Wed Feb 13, 2008 1:35 pm
Thanks you for reply.
Send the screen
micman2
Post by micman2 » Wed Feb 13, 2008 1:39 pm
after I change "rtw_alt_pathname"
Post by LubinKerhuel » Wed Feb 13, 2008 4:58 pm
from viewtopic.php?f=5&t=73#p152 :
LubinKerhuel wrote:You can check by typing at the matlab prompt the command:
rtw_alt_pathname('C:\Program Files\Microchip\MPLAB C30')
If you do not get C:\PROGRA~1\MICROC~1\MPLABC~1, you will have to change the short path in Simulink :
Simulation ==> Configuration Parameters ==> Real-Time Workshop ==> DsPIC options
did you correct the parameters in the simulink model :
(part 2 of the solution)
micman2
Post by micman2 » Wed Feb 13, 2008 5:10 pm
I see this
Post by LubinKerhuel » Wed Feb 13, 2008 6:11 pm
Something is wrong.
In the Real Time Workshop , you have
- Comment
- Symbols
- Custom Code
- Debug
You should have
- Comment
- Symbols
- Custom Code
- Debug
- DsPIC options
Could you try to select another target than dsPIC.tlc (ert.tlc or any other), click apply, then, choose again dsPIC.tlc, click apply and look at the command windows for any error? Could you report the error you get here?
Which matlab version are you using?
I will try to find out what's happening as soon as I can...
micman2
Post by micman2 » Wed Feb 13, 2008 6:33 pm
The file dspic.tlc is correct but when load there isn't "DsPIC options"
micman2
Post by micman2 » Wed Feb 13, 2008 6:35 pm
and I've simulink version :
micman2
Post by micman2 » Wed Feb 13, 2008 6:37 pm
Matlab version:
micman2
Post by micman2 » Wed Feb 13, 2008 6:43 pm
Error:
Warning: Error using ==> getSTFInfo at 76
The following error occurred processing the System Target File '':
Error using ==> getPathName
The path 'C:\Program Files\Microchip\MPLAB C30' does not exist
> In C:\Programmi\MATLAB\R2007b\toolbox\rtw\rtw\stf2target.p>stf2target at 61
In open at 148
In uiopen at 196
Warning: Error evaluating 'LoadFcn' callback of Master block (mask) 'Master'. Error using ==> dsPIC_ConfigRTWOption
at 34
The *System Target File must be defined to dsPIC Real Time workshop (Simulation ==> Configuration Parameters ==>
Real Time workshop.
In open at 148
In uiopen at 196
Warning: In instantiating linked block 'Servo_ADC/ADC Input' : Invalid setting in dsPIC : ADC10 block (mask) 'ADC
Input' for parameter 'OutFormatBitspopup'.
> In C:\MyToolBox\blocks\dsPIC_PWM_OC_callback.p>dsPIC_PWM_OC_callback at 94
In open at 148
In uiopen at 196
at 34
Real Time workshop.
> In C:\MyToolBox\blocks\dsPIC_ADC_callback_InitMask.p>dsPIC_ADC_callback_InitMask at 9
In open at 148
In uiopen at 196
In C:\Programmi\MATLAB\R2007b\toolbox\rtw\rtw\@RTW\@TargetBrowser\uploadTarget.p>uploadTarget at 20
In C:\Programmi\MATLAB\R2007b\toolbox\rtw\rtw\private\targetBrowserCloseCB.p>targetBrowserCloseCB at 9
In C:\Programmi\MATLAB\R2007b\toolbox\rtw\rtw\rtwprivate.p>rtwprivate at 12
In simulink\private\configDlgAction at 93
In slprivate at 12
In slprivate at 12
Post by LubinKerhuel » Wed Feb 13, 2008 7:23 pm
This is a bug !
I'll correct that. Thanks for screenshoot and bug description...
Post by LubinKerhuel » Wed Feb 13, 2008 8:50 pm
It's corrected, C30 can now be installed in the directory : C:\Programmi\Microchip\MPLAB C30 or in the directory : C:\Program Files\Microchip\MPLAB C30
Could you give a try to the new version ? (download it on from website)
micman2
Post by micman2 » Thu Feb 14, 2008 9:06 am
wow :D now work!!! Thank you
dsPIC_ConfigRTWOption at 34
Real Time workshop.
  In open at 148
  In uiopen at 196
  In open at 148
  In uiopen at 196
Number of I/O PINs used : 2
### Starting Real-Time Workshop build procedure for model: Servo_ADC
### Generating code into build directory: C:\MyToolBox\examples\Servo_ADC_dspic\sources
Warning: Source 'Servo_ADC/ADC Input' specifies that its sample time (-1) is back-inherited. You should explicitly
specify the sample time of sources. You can disable this diagnostic by setting the 'Source block specifies -1
sample time' diagnostic to 'none' in the Sample Time group on the Diagnostics pane of the Configuration Parameters
dialog box.
### Invoking Target Language Compiler on Servo_ADC.rtw
	tlc
	-r
	C:\MyToolBox\examples\Servo_ADC_dspic\sources\Servo_ADC.rtw
	C:\MyToolBox\dspic\dspic.tlc
	-OC:\MyToolBox\examples\Servo_ADC_dspic\sources
	-IC:\MyToolBox\dspic
	-IC:\MyToolBox\blocks
	-IC:\MyToolBox\examples\Servo_ADC_dspic\sources\tlc
	-IC:\Programmi\MATLAB\R2007b\rtw\c\tlc\mw
	-IC:\Programmi\MATLAB\R2007b\rtw\c\tlc\lib
	-IC:\Programmi\MATLAB\R2007b\rtw\c\tlc\blocks
	-IC:\Programmi\MATLAB\R2007b\rtw\c\tlc\fixpt
	-IC:\Programmi\MATLAB\R2007b\stateflow\c\tlc
	-aEnforceIntegerDowncast=1
	-aFoldNonRolledExpr=1
	-aInlineInvariantSignals=0
	-aInlineParameters=0
	-aLocalBlockOutputs=1
	-aRollThreshold=5
	-aInitFltsAndDblsToZero=1
	-aGenerateReport=0
	-aGenCodeOnly=0
	-aRTWVerbose=1
	-aIncludeHyperlinkInReport=0
	-aLaunchReport=0
	-aGenerateTraceInfo=0
	-aForceParamTrailComments=0
	-aGenerateComments=1
	-aIncHierarchyInIds=0
	-aMaxRTWIdLen=31
	-aShowEliminatedStatements=0
	-aIncDataTypeInIds=0
	-aInsertBlockDesc=0
	-aSimulinkBlockComments=1
	-aInlinedPrmAccess="Literals"
	-aIsPILTarget=0
	-aIncludeMdlTerminateFcn=0
	-aCombineOutputUpdateFcns=1
	-aSuppressErrorStatus=1
	-aERTCustomFileBanners=1
	-aLogVarNameModifier="rt_"
	-aGenerateFullHeader=1
	-aGenerateSampleERTMain=0
	-aMatFileLogging=0
	-aMultiInstanceERTCode=0
	-aPurelyIntegerCode=0
	-aPortableWordSizes=0
	-aGenerateErtSFunction=0
	-aGenerateASAP2=0
	-aExtMode=0
	-aExtModeStaticAlloc=0
	-aExtModeTransport=0
	-aExtModeTesting=0
	-aTargetOS="BareBoardExample"
	-aRateGroupingCode=1
	-aRTWCAPISignals=0
	-aRTWCAPIParams=0
	-aRootIOStructures=0
	-aLDPICTYPE="-T C:\PROGRA~1\MICROC~1\MPLABC~2\support\gld\p30f3012.gld"
	-aLDLIBPIC="C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libpic30-coff.a  C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libp30F3012-coff.a C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libc-coff.a C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libm-coff.a"
	-aPIC_REF="30f3012"
	-p10000
### Writing header file Servo_ADC_types.h
### Writing header file Servo_ADC.h
### Writing source file Servo_ADC.c
### Writing header file Servo_ADC_private.h
### Writing source file Servo_ADC_data.c
### Writing source file Servo_ADC_main.c
Companie =
Embedded Coder for dsPIC V0.96b(13-Feb-2008) for Matlab R2007b.
informations available at  http://www.kerhuel.eu
### Processing Template Makefile: C:\MyToolBox\dspic\dspic_pic30_gcc.tmf
###    <C:\PROGRA~1\MATLAB\R2007b\bin\win32\gmake>
### in default batch file
### Creating Servo_ADC.mk from C:\MyToolBox\dspic\dspic_pic30_gcc.tmf
### Building Servo_ADC: .\Servo_ADC.bat
C:\MyToolBox\examples\Servo_ADC_dspic\sources>set MATLAB=C:\Programmi\MATLAB\R2007b
C:\MyToolBox\examples\Servo_ADC_dspic\sources>C:\PROGRA~1\MATLAB\R2007b\bin\win32\gmake -f Servo_ADC.mk  GENERATE_REPORT=0 MULTI_INSTANCE_CODE=0 PORTABLE_WORDSIZES=0 GENERATE_ASAP2=0 TMW_EXTMODE_TESTING=0
pic30-gcc  -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2	 -O   -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc   -I C:\PROGRA~1\MICROC~1\MPLABC~2\include    Servo_ADC_data.c
pic30-gcc  -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2	 -O   -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc   -I C:\PROGRA~1\MICROC~1\MPLABC~2\include    Servo_ADC_main.c
Servo_ADC_main.c: In function 'main':
Servo_ADC_main.c:58: warning: 'return' with a value, in function returning void
Servo_ADC_main.c:48: warning: return type of 'main' is not 'int'
pic30-gcc  -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2	 -O   -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc   -I C:\PROGRA~1\MICROC~1\MPLABC~2\include    dsPIC_OutputCompare_Interrupt.c
dsPIC_OutputCompare_Interrupt.c: In function '_OC1Interrupt':
dsPIC_OutputCompare_Interrupt.c:7: warning:  PSV model not specified for '_OC1Interrupt';
pic30-gcc  -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2	 -O   -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc   -I C:\PROGRA~1\MICROC~1\MPLABC~2\include    Servo_ADC.c
pic30-gcc  -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2	 -O   -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc   -I C:\PROGRA~1\MICROC~1\MPLABC~2\include    C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_backsubcc_dbl.c
pic30-gcc  -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2	 -O   -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc   -I C:\PROGRA~1\MICROC~1\MPLABC~2\include    C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_backsubcc_sgl.c
pic30-gcc  -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2	 -O   -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc   -I C:\PROGRA~1\MICROC~1\MPLABC~2\include    C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_backsubrc_dbl.c
pic30-gcc  -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2	 -O   -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc   -I C:\PROGRA~1\MICROC~1\MPLABC~2\include    C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_backsubrc_sgl.c
pic30-gcc  -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2	 -O   -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc   -I C:\PROGRA~1\MICROC~1\MPLABC~2\include    C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_backsubrr_dbl.c
pic30-gcc  -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2	 -O   -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc   -I C:\PROGRA~1\MICROC~1\MPLABC~2\include    C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_backsubrr_sgl.c
pic30-gcc  -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2	 -O   -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc   -I C:\PROGRA~1\MICROC~1\MPLABC~2\include    C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_enab.c
pic30-gcc  -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2	 -O   -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc   -I C:\PROGRA~1\MICROC~1\MPLABC~2\include    C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_forwardsubcc_dbl.c
pic30-gcc  -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2	 -O   -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc   -I C:\PROGRA~1\MICROC~1\MPLABC~2\include    C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_forwardsubcc_sgl.c
pic30-gcc  -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2	 -O   -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc   -I C:\PROGRA~1\MICROC~1\MPLABC~2\include    C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_forwardsubcr_dbl.c
pic30-gcc  -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2	 -O   -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc   -I C:\PROGRA~1\MICROC~1\MPLABC~2\include    C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_forwardsubcr_sgl.c
pic30-gcc  -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2	 -O   -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc   -I C:\PROGRA~1\MICROC~1\MPLABC~2\include    C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_forwardsubrc_dbl.c
pic30-gcc  -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2	 -O   -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc   -I C:\PROGRA~1\MICROC~1\MPLABC~2\include    C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_forwardsubrc_sgl.c
pic30-gcc  -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2	 -O   -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc   -I C:\PROGRA~1\MICROC~1\MPLABC~2\include    C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_forwardsubrr_dbl.c
pic30-gcc  -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2	 -O   -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc   -I C:\PROGRA~1\MICROC~1\MPLABC~2\include    C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_forwardsubrr_sgl.c
pic30-gcc  -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2	 -O   -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc   -I C:\PROGRA~1\MICROC~1\MPLABC~2\include    C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_look.c
pic30-gcc  -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2	 -O   -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc   -I C:\PROGRA~1\MICROC~1\MPLABC~2\include    C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_look1d.c
pic30-gcc  -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2	 -O   -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc   -I C:\PROGRA~1\MICROC~1\MPLABC~2\include    C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_look1d32.c
pic30-gcc  -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2	 -O   -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc   -I C:\PROGRA~1\MICROC~1\MPLABC~2\include    C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_look2d32_general.c
pic30-gcc  -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2	 -O   -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc   -I C:\PROGRA~1\MICROC~1\MPLABC~2\include    C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_look2d32_normal.c
pic30-gcc  -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2	 -O   -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc   -I C:\PROGRA~1\MICROC~1\MPLABC~2\include    C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_look2d_general.c
pic30-gcc  -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2	 -O   -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc   -I C:\PROGRA~1\MICROC~1\MPLABC~2\include    C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_look2d_normal.c
pic30-gcc  -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2	 -O   -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc   -I C:\PROGRA~1\MICROC~1\MPLABC~2\include    C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_look32.c
pic30-gcc  -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2	 -O   -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc   -I C:\PROGRA~1\MICROC~1\MPLABC~2\include    C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_lu_cplx.c
pic30-gcc  -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2	 -O   -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc   -I C:\PROGRA~1\MICROC~1\MPLABC~2\include    C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_lu_cplx_sgl.c
pic30-gcc  -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2	 -O   -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc   -I C:\PROGRA~1\MICROC~1\MPLABC~2\include    C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_lu_real.c
pic30-gcc  -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2	 -O   -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc   -I C:\PROGRA~1\MICROC~1\MPLABC~2\include    C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_lu_real_sgl.c
pic30-gcc  -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2	 -O   -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc   -I C:\PROGRA~1\MICROC~1\MPLABC~2\include    C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_matdivcc_dbl.c
pic30-gcc  -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2	 -O   -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc   -I C:\PROGRA~1\MICROC~1\MPLABC~2\include    C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_matdivcc_sgl.c
pic30-gcc  -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2	 -O   -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc   -I C:\PROGRA~1\MICROC~1\MPLABC~2\include    C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_matdivcr_dbl.c
pic30-gcc  -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2	 -O   -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc   -I C:\PROGRA~1\MICROC~1\MPLABC~2\include    C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_matdivcr_sgl.c
pic30-gcc  -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2	 -O   -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc   -I C:\PROGRA~1\MICROC~1\MPLABC~2\include    C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_matdivrc_dbl.c
pic30-gcc  -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2	 -O   -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc   -I C:\PROGRA~1\MICROC~1\MPLABC~2\include    C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_matdivrc_sgl.c
pic30-gcc  -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2	 -O   -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc   -I C:\PROGRA~1\MICROC~1\MPLABC~2\include    C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_matdivrr_dbl.c
pic30-gcc  -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2	 -O   -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc   -I C:\PROGRA~1\MICROC~1\MPLABC~2\include    C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_matdivrr_sgl.c
pic30-gcc  -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2	 -O   -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc   -I C:\PROGRA~1\MICROC~1\MPLABC~2\include    C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_matmultandinccc_dbl.c
pic30-gcc  -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2	 -O   -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc   -I C:\PROGRA~1\MICROC~1\MPLABC~2\include    C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_matmultandinccc_sgl.c
pic30-gcc  -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2	 -O   -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc   -I C:\PROGRA~1\MICROC~1\MPLABC~2\include    C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_matmultandinccr_dbl.c
pic30-gcc  -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2	 -O   -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc   -I C:\PROGRA~1\MICROC~1\MPLABC~2\include    C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_matmultandinccr_sgl.c
pic30-gcc  -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2	 -O   -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc   -I C:\PROGRA~1\MICROC~1\MPLABC~2\include    C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_matmultandincrc_dbl.c
pic30-gcc  -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2	 -O   -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc   -I C:\PROGRA~1\MICROC~1\MPLABC~2\include    C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_matmultandincrc_sgl.c
pic30-gcc  -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2	 -O   -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc   -I C:\PROGRA~1\MICROC~1\MPLABC~2\include    C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_matmultandincrr_dbl.c
pic30-gcc  -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2	 -O   -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc   -I C:\PROGRA~1\MICROC~1\MPLABC~2\include    C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_matmultandincrr_sgl.c
pic30-gcc  -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2	 -O   -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc   -I C:\PROGRA~1\MICROC~1\MPLABC~2\include    C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_matmultcc_dbl.c
pic30-gcc  -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2	 -O   -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc   -I C:\PROGRA~1\MICROC~1\MPLABC~2\include    C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_matmultcc_sgl.c
pic30-gcc  -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2	 -O   -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc   -I C:\PROGRA~1\MICROC~1\MPLABC~2\include    C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_matmultcr_dbl.c
pic30-gcc  -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2	 -O   -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc   -I C:\PROGRA~1\MICROC~1\MPLABC~2\include    C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_matmultcr_sgl.c
pic30-gcc  -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2	 -O   -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc   -I C:\PROGRA~1\MICROC~1\MPLABC~2\include    C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_matmultrc_dbl.c
pic30-gcc  -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2	 -O   -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc   -I C:\PROGRA~1\MICROC~1\MPLABC~2\include    C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_matmultrc_sgl.c
pic30-gcc  -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2	 -O   -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc   -I C:\PROGRA~1\MICROC~1\MPLABC~2\include    C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_matmultrr_dbl.c
pic30-gcc  -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2	 -O   -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc   -I C:\PROGRA~1\MICROC~1\MPLABC~2\include    C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_matmultrr_sgl.c
pic30-gcc  -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2	 -O   -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc   -I C:\PROGRA~1\MICROC~1\MPLABC~2\include    C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_sat_div_int16.c
pic30-gcc  -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2	 -O   -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc   -I C:\PROGRA~1\MICROC~1\MPLABC~2\include    C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_sat_div_int32.c
pic30-gcc  -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2	 -O   -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc   -I C:\PROGRA~1\MICROC~1\MPLABC~2\include    C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_sat_div_int8.c
pic30-gcc  -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2	 -O   -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc   -I C:\PROGRA~1\MICROC~1\MPLABC~2\include    C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_sat_div_uint16.c
pic30-gcc  -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2	 -O   -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc   -I C:\PROGRA~1\MICROC~1\MPLABC~2\include    C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_sat_div_uint32.c
pic30-gcc  -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2	 -O   -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc   -I C:\PROGRA~1\MICROC~1\MPLABC~2\include    C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_sat_div_uint8.c
pic30-gcc  -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2	 -O   -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc   -I C:\PROGRA~1\MICROC~1\MPLABC~2\include    C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_sat_prod_int16.c
pic30-gcc  -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2	 -O   -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc   -I C:\PROGRA~1\MICROC~1\MPLABC~2\include    C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_sat_prod_int32.c
pic30-gcc  -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2	 -O   -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc   -I C:\PROGRA~1\MICROC~1\MPLABC~2\include    C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_sat_prod_int8.c
pic30-gcc  -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2	 -O   -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc   -I C:\PROGRA~1\MICROC~1\MPLABC~2\include    C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_sat_prod_uint16.c
pic30-gcc  -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2	 -O   -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc   -I C:\PROGRA~1\MICROC~1\MPLABC~2\include    C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_sat_prod_uint32.c
pic30-gcc  -c -mcpu=30F2010 -O3 -fschedule-insns -fschedule-insns2	 -O   -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\Servo_ADC_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc   -I C:\PROGRA~1\MICROC~1\MPLABC~2\include    C:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc/rt_sat_prod_uint8.c
"### Creating rtwlib.a "
pic30-ar -r rtwlib.a rt_backsubcc_dbl.o rt_backsubcc_sgl.o rt_backsubrc_dbl.o rt_backsubrc_sgl.o rt_backsubrr_dbl.o rt_backsubrr_sgl.o rt_enab.o rt_forwardsubcc_dbl.o rt_forwardsubcc_sgl.o rt_forwardsubcr_dbl.o rt_forwardsubcr_sgl.o rt_forwardsubrc_dbl.o rt_forwardsubrc_sgl.o rt_forwardsubrr_dbl.o rt_forwardsubrr_sgl.o rt_look.o rt_look1d.o rt_look1d32.o rt_look2d32_general.o rt_look2d32_normal.o rt_look2d_general.o rt_look2d_normal.o rt_look32.o rt_lu_cplx.o rt_lu_cplx_sgl.o rt_lu_real.o rt_lu_real_sgl.o rt_matdivcc_dbl.o rt_matdivcc_sgl.o rt_matdivcr_dbl.o rt_matdivcr_sgl.o rt_matdivrc_dbl.o rt_matdivrc_sgl.o rt_matdivrr_dbl.o rt_matdivrr_sgl.o rt_matmultandinccc_dbl.o rt_matmultandinccc_sgl.o rt_matmultandinccr_dbl.o rt_matmultandinccr_sgl.o rt_matmultandincrc_dbl.o rt_matmultandincrc_sgl.o rt_matmultandincrr_dbl.o rt_matmultandincrr_sgl.o rt_matmultcc_dbl.o rt_matmultcc_sgl.o rt_matmultcr_dbl.o rt_matmultcr_sgl.o rt_matmultrc_dbl.o rt_matmultrc_sgl.o rt_matmultrr_dbl.o rt_matmultrr_sgl.o rt_sat_div_int16.o rt_sat_div_int32.o rt_sat_div_int8.o rt_sat_div_uint16.o rt_sat_div_uint32.o rt_sat_div_uint8.o rt_sat_prod_int16.o rt_sat_prod_int32.o rt_sat_prod_int8.o rt_sat_prod_uint16.o rt_sat_prod_uint32.o rt_sat_prod_uint8.o
"### rtwlib.a Created"
pic30-ld   -t --report-mem -Map ../untitled.map --heap 0  -cref -T C:\PROGRA~1\MICROC~1\MPLABC~2\support\gld\p30f2010.gld -o ..\../Servo_ADC.coff  Servo_ADC_data.o Servo_ADC_main.o dsPIC_OutputCompare_Interrupt.o Servo_ADC.o     rtwlib.a  C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libpic30-coff.a  C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libp30F2010-coff.a C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libc-coff.a C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libm-coff.a
C:\Programmi\Microchip\MPLAB C30\bin\pic30-coff-ld.exe: mode pic30_coff
Servo_ADC_data.o
Servo_ADC_main.o
Servo_ADC.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libpic30-coff.a)crt1.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libpic30-coff.a)crt0.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libp30F2010-coff.a)ConfigIntTimer1.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libp30F2010-coff.a)ConfigIntTimer2.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libp30F2010-coff.a)OpenTimer2.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libp30F2010-coff.a)OpenOC1.o
(C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libp30F2010-coff.a)ConfigIntOC1.o
Program Memory Usage
section                    address   length (PC units)   length (bytes) (dec)
.reset                           0                 0x4             0x6  (6)
.ivt                           0x4                0x7c            0xba  (186)
.aivt                         0x84                0x7c            0xba  (186)
.text                        0x100               0x1d4           0x2be  (702)
.dinit                       0x2d4                0x1e            0x2d  (45)
.isr                         0x2f2                 0x2             0x3  (3)
__FOSC                    0xf80000                 0x2             0x3  (3)
__FWDT                    0xf80002                 0x2             0x3  (3)
__FBORPOR                 0xf80004                 0x2             0x3  (3)
__FGS                     0xf8000a                 0x2             0x3  (3)
                     Total program memory used (bytes):          0x474  (1140) 9%
Data Memory Usage
section                    address      alignment gaps    total length  (dec)
.ndata                       0x800                   0             0x6  (6)
.nbss                        0x806                   0             0x4  (4)
.nbss                        0x80a                   0             0x4  (4)
.nbss                        0x80e                   0             0x2  (2)
                        Total data memory used (bytes):           0x10  (16) 3%
Dynamic Memory Usage
region                     address                      maximum length  (dec)
heap                             0                                   0  (0)
stack                        0x810                               0x1f0  (496)
                        Maximum dynamic memory (bytes):          0x1f0  (496)
"*** Embedded Target for dsPIC written by Lubin KERHUEL -  http://www.kerhuel.eu"
"*** Licence Accorded to Demonstration Version                                                              "
"*** Version 0.96b                             13-Feb-2008      "
"*** For Matlab 7.5             R2007b       "
"*** Created "executable": ..\../Servo_ADC.coff"
pic30-coff-bin2hex ..\../Servo_ADC.coff
"*** Created "executable": ..\../Servo_ADC.hex"
### Successful completion of Real-Time Workshop build procedure for model: Servo_ADC
micman2
Post by micman2 » Thu Feb 14, 2008 10:08 am
There is a problem, when compiling example "Servo_ADC.mdl" work very well , but when compiling another example give me error:
Post by LubinKerhuel » Thu Feb 14, 2008 1:28 pm
I can't see the error on the image (it is cut) however, I guess that it says that the linker script ***.gld is missing.
This script is provided with the C30 compiler. Could you check that you installed it and that it is present in the correct directory?
micman2
Post by micman2 » Thu Feb 14, 2008 2:02 pm
Ok resolve it , the problem is :
Now all the examples are compiled perfectly.
But I did a test in dsPIC33_f_Explorer16 I changed into "dspic master processor in the box PIC24fj128GA10, make an error "Error ==> genMakefileAndBuild at 1070"
micman2
Post by micman2 » Thu Feb 14, 2008 2:06 pm
change processor and the error is:
informations available at  www.kerhuel.eu
### Creating dsPIC_33f_Explorer16.mk from C:\MyToolBox\dspic\dspic_pic30_gcc.tmf
### Building dsPIC_33f_Explorer16: .\dsPIC_33f_Explorer16.bat
C:\MyToolBox\examples\dsPIC_33f_Explorer16_dspic\sources>set MATLAB=C:\Programmi\MATLAB\R2007b
C:\MyToolBox\examples\dsPIC_33f_Explorer16_dspic\sources>C:\PROGRA~1\MATLAB\R2007b\bin\win32\gmake -f dsPIC_33f_Explorer16.mk  GENERATE_REPORT=1 MULTI_INSTANCE_CODE=0 PORTABLE_WORDSIZES=0 GENERATE_ASAP2=0 TMW_EXTMODE_TESTING=0
pic30-gcc  -c -mcpu=p24FJ128GA010 -O3 -fschedule-insns -fschedule-insns2	 -O   -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\dsPIC_33f_Explorer16_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc   -I C:\PROGRA~1\MICROC~1\MPLABC~2\include    dsPIC_33f_Explorer16_main.c
pic30-coff-cc1.exe: error: Invalid -mcpu option.  CPU p24FJ128GA010 not recognized.
Warning: In instantiating linked block 'dsPIC_33f_Explorer16/Master' : Invalid setting in Master block (mask)
'Master' for parameter 'MCLR'.
  In open at 148
  In uiopen at 196
Number of I/O PINs used : 6
### Starting Real-Time Workshop build procedure for model: dsPIC_33f_Explorer16
### Generating code into build directory: C:\MyToolBox\examples\dsPIC_33f_Explorer16_dspic\sources
Warning: Source 'dsPIC_33f_Explorer16/Digital Input' specifies that its sample time (-1) is back-inherited. You
should explicitly specify the sample time of sources. You can disable this diagnostic by setting the 'Source block
specifies -1 sample time' diagnostic to 'none' in the Sample Time group on the Diagnostics pane of the
Configuration Parameters dialog box.
### Invoking Target Language Compiler on dsPIC_33f_Explorer16.rtw
	tlc
	-r
	C:\MyToolBox\examples\dsPIC_33f_Explorer16_dspic\sources\dsPIC_33f_Explorer16.rtw
	-OC:\MyToolBox\examples\dsPIC_33f_Explorer16_dspic\sources
	-IC:\MyToolBox\examples\dsPIC_33f_Explorer16_dspic\sources\tlc
	-aEnforceIntegerDowncast=0
	-aInlineInvariantSignals=1
	-aInlineParameters=1
	-aRollThreshold=5
	-aZeroInternalMemoryAtStartup=0
	-aZeroExternalMemoryAtStartup=0
	-aInitFltsAndDblsToZero=0
	-aGenerateReport=1
	-aGenCodeOnly=0
	-aRTWVerbose=1
	-aIncludeHyperlinkInReport=1
	-aLaunchReport=1
	-aMaxRTWIdLen=31
	-aInsertBlockDesc=0
	-aIsPILTarget=0
	-aMatFileLogging=0
	-aGenerateASAP2=0
	-aExtMode=0
	-aExtModeTesting=0
	-aRTWCAPISignals=0
	-aRTWCAPIParams=0
	-aOPTIM_GCC="-mcpu=24FJ128GA010 -O3 -fschedule-insns -fschedule-insns2"
	-aLDPICTYPE="-T C:\PROGRA~1\MICROC~1\MPLABC~2\support\gld\p24fj128ga010.gld"
	-aLDLIBPIC="C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libpic30-coff.a  C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libpPIC24Fxxx-coff.a C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libc-coff.a C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libm-coff.a"
	-aPIC_REF="24fj128ga010"
	-p10000
### Writing header file dsPIC_33f_Explorer16_types.h
### Writing header file dsPIC_33f_Explorer16.h
### Writing source file dsPIC_33f_Explorer16.c
### Writing header file dsPIC_33f_Explorer16_private.h
### Writing source file dsPIC_33f_Explorer16_main.c
### Creating HTML report file dsPIC_33f_Explorer16_codegen_rpt.html
Companie =
pic30-gcc  -c -mcpu=24FJ128GA010 -O3 -fschedule-insns -fschedule-insns2	 -O   -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\MyToolBox\examples\dsPIC_33f_Explorer16_dspic\sources -IC:\MyToolBox\examples -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc   -I C:\PROGRA~1\MICROC~1\MPLABC~2\include    dsPIC_33f_Explorer16_main.c
In file included from c:/programmi/microchip/mplab c30/bin/../support/h/peripheral_24F/timer.h:34,
                 from dsPIC_33f_Explorer16_private.h:33,
c:/programmi/microchip/mplab c30/bin/../support/h/peripheral_24F/Generic.h:56: error: syntax error before '(' token
micman2
Post by micman2 » Thu Feb 14, 2008 2:10 pm
PS: excuse me for my screenshoot and my english :D
And thank you for your disponibility :D
Post by LubinKerhuel » Thu Feb 14, 2008 4:55 pm
There is a know bug for 24fj PIC.
I do not know why, if anybody has a suggestion.
The solution is described on the release page: http://www.kerhuel.eu/RTWdsPIC/ReleaseNotes.html
Know bug : before compiling schematic for dsPIC 24f, you must remove the line 56 of Generic.h file which is in
"C:\Program Files\Microchip\MPLAB C30\support\h\peripheral_24F"
The line :
"typedef enum _BOOL { FALSE = 0, TRUE } BOOL;" does not compile !
micman2
Post by micman2 » Thu Feb 14, 2008 5:15 pm
Sorry I had not seen, now everything works perfectly thanks :D :D :D
