I am receiving compiling error wrt to "GenericTypeDefs.h:60: error: syntax error before '(' token" while am trying to compile a programme with 2 uart for both PIC32 starter kits and cerebot 32mx
here is error message:
### Processing Template Makefile: D:\LUBIN BLOCKSETS\install_dsPIC_R2007b_PhD_Ismaeel_Tijani_Shahril_Pawanchee_Malaysia (1)\dspic\pic32_gcc.tmf
### Creating UAV_controllerMCU.mk from D:\LUBIN BLOCKSETS\install_dsPIC_R2007b_PhD_Ismaeel_Tijani_Shahril_Pawanchee_Malaysia (1)\dspic\pic32_gcc.tmf
### Building UAV_controllerMCU: "C:\PROGRA~1\MATLAB\R2007b\bin\win32\gmake" -f UAV_controllerMCU.mk GENERATE_REPORT=0 MULTI_INSTANCE_CODE=0 PORTABLE_WORDSIZES=0 GENERATE_ASAP2=0 TMW_EXTMODE_TESTING=0
''pic32-gcc -c -mprocessor=32MX460F512L -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -ID:\EMBEDD~1\UAVDAQ~1\UAV_PI~1\UAV_CO~2\sources -ID:\EMBEDD~1\UAVDAQ~1\UAV_PI~1 -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc -IC:\MICROC~1\PIC32S~1\MPLABC~1\pic32mx\include -IC:\MICROC~1\PIC32S~1\MPLABC~1\pic32mx\include\peripheral UAV_controllerMCU_data.c
UAV_controllerMCU_data.c:1: warning: Compiler option ignored due to an expired standard-evaluation period
UAV_controllerMCU_data.c:1: warning: Disable the option or visit http://www.microchip.com/c32 to purchase a full standard-edition license.
In file included from C:/MICROC~1/PIC32S~1/MPLABC~1/pic32mx/include/peripheral/uart.h:52,
from UAV_controllerMCU_private.h:40,
from UAV_controllerMCU_data.c:28:
C:/MICROC~1/PIC32S~1/MPLABC~1/pic32mx/include/GenericTypeDefs.h:60: error: syntax error before '(' token
gmake: *** [UAV_controllerMCU_data.o] Error 1
### Real-Time Workshop build procedure for model: 'UAV_controllerMCU' aborted due
I already tried to follow one of your response here, I comment out line 60 of the .h file, but error is the same.
what could be the problem pls.
thanks
compiling error for PIC32 starter kits
- UAV_controllerMCU_USBkit.mdl
- (112.73 KiB) Downloaded 954 times
Re: compiling error for PIC32 starter kits
I removed one of the UART, and use only one 2A, it compiled without error. So the problem is ignited by the use of the two UART 1A and 2A at the same time.
So, what can you suggest pls as way out.
thanks
thanks
