Can't run examples
Posted: Tue Dec 11, 2012 2:31 am
Hello:
I have just download and installed the dsPIC blockset. It was installed properly and it is not included on the matlab directory.
I checked that the matlab folder is set to the dspic blocks folder.
I am using matlab R2010a on windows 7 64bit.
However when I try to compile the examples the following error appears:
File I/O error on file 'dspic.tlc'
Operation that caused an error: open
I am kind of lost here. If someone could explain what does this means and how to workaround that error I would be most thankful.
thank
thank
