Warning at opening time and can't open dialog in library
Posted: Tue Jul 17, 2007 9:24 am
hi, Lubin
I dowload the "install_dsPIC_R2007a.zip" from your website today, then install it acording to your installing instructions. all is ok.
but, when dual click the "Embedded Tartget for Microchip dsPIC" from the "Simulink Library Browse", the following warning occurs:
Warning: Error evaluating 'LoadFcn' callback of Master block (mask) 'Master'. Error using ==> dsPIC_ConfigRTWOption at 34
> In load_system at 52
In libbrowse>i_LoadSys at 142
In libbrowse>LoadLibrary at 121
In libbrowse at 24
why?
Expect your reply.
and the "dsPIC_33f_Explorer16.mdl" can be open, but the warning is followed:
>> open dsPIC_33f_Explorer16.mdl
Warning: In instantiating linked block 'dsPIC_33f_Explorer16/Master' : Invalid setting in Master block (mask) 'Master' for parameter 'FPBOR'.
In open at 146
Warning: In instantiating linked block 'dsPIC_33f_Explorer16/Master' : Invalid setting in Master block (mask) 'Master' for parameter 'MCLR'.
In open at 146
Warning: In instantiating linked block 'dsPIC_33f_Explorer16/ADC Input' : dsPIC : ADC10 block (mask) does not have a parameter named 'ADC_TYPE12'.
> In F:\blocks\dsPIC_ConfigRTWOption.p>dsPIC_ConfigRTWOption at 4
In F:\blocks\dsPIC_MASTER_callback.p>dsPIC_MASTER_callback at 87
In open at 146
Warning: In instantiating linked block 'dsPIC_33f_Explorer16/ADC Input' : dsPIC : ADC10 block (mask) does not have a parameter named 'VoltRef'.
In open at 146
Warning: In instantiating linked block 'dsPIC_33f_Explorer16/ADC Input' : dsPIC : ADC10 block (mask) does not have a parameter named 'OutFormatBits'.
In open at 146
Warning: In instantiating linked block 'dsPIC_33f_Explorer16/ADC Input' : dsPIC : ADC10 block (mask) does not have a parameter named 'NCHANNEL'.
In open at 146
Warning: In instantiating linked block 'dsPIC_33f_Explorer16/ADC Input' : dsPIC : ADC10 block (mask) does not have a parameter named 'ANCHANNELS_BITEWISE'.
In open at 146
NbrPortUsed is 6
why?
In libbrowse at 24
why?
Expect your reply.
In open at 146
In open at 146
In open at 146
In open at 146
In open at 146
In open at 146
In open at 146
NbrPortUsed is 6
why?
