error 255 - tcpip not found
Posted: Tue May 03, 2011 12:40 pm
by joanpamo
Hello. Thank you for this great utility.
I have a problem, and I don't know how solve it: when I compile a simple proyect (only with one configuration blockset) the next error occurs:
prueba1_main.c: In function '_FICD':
prueba1_main.c:36: error: syntax error before '{' token
gmake: *** [prueba1_main.o] Error 255
### Real-Time Workshop build procedure for model: 'prueba1' aborted due to an error.
I searched the file tcpip in this directory, but it wasn't there.
Thank you very much again
Re: error 255 - tcpip not found
Posted: Tue May 03, 2011 1:06 pm
joanpamo wrote:--dir C:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/tcpip not found. It is not added to MPLAB project.
This is not the bug.
joanpamo wrote:prueba1_main.c: In function '_FICD':
This is the bug.
Which PIC/dsPIC did you choosed in the Master block ?
Posted: Wed May 04, 2011 9:21 am
by joanpamo
Ok, I choosed dsPIC 30f4013, with the dsPIC master blockset
Posted: Fri May 06, 2011 5:43 pm
I used extensively the dsPIC30f4013 and it should not have this kind of bug.
Could you please upload the simulink model you are using on that forum ? (upload attachment at the bottom).
Posted: Sat May 07, 2011 4:14 pm
by joanpamo
I'm uploading the simulink model that I use. It's the example that there is on:
http://www.kerhuel.eu/wiki/Animation_Co ... irst_model, but it's applied to dsPIC30f4013. All properties of the dsPIC's blockset are default, in order not to get errors.
In the last compilation, I changed from my computer to another that had installed winXP, instead win7 (like first one) And the result was:
*** Alternatively, (re-)compile the MPLAB project : Within Matlab, right-click example1.mcp -> open outside Matlab will open the MPLAB project. Compile, modify..."
### Successful completion of Real-Time Workshop build procedure for model: example1
It still doesn't found
tcpip, but there no error.
I'm very grateful for your interest. Thank you very much again
Posted: Sat Feb 11, 2012 7:31 am
by jekson
hello LubinKerhuel
thanks for the tool.
I have the same problem joanpamo, this is my error.
### Processing Template Makefile: C:\Users\alex\Documents\MATLAB\dspic\dspic_pic30_gcc.tmf
### Creating dsPIC_33f_Explorer16.mk from C:\Users\alex\Documents\MATLAB\dspic\dspic_pic30_gcc.tmf
### Building dsPIC_33f_Explorer16: "C:\PROGRA~1\MATLAB\R2010a\bin\win32\gmake" -f dsPIC_33f_Explorer16.mk GENERATE_REPORT=0 MULTI_INSTANCE_CODE=0 PORTABLE_WORDSIZES=0 GENERATE_ASAP2=0 TMW_EXTMODE_TESTING=0
''pic30-gcc -c -mcpu=24fJ96GA010 -O3 -fschedule-insns -fschedule-insns2 -O -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2010a/simulink/include -IC:\PROGRA~1\MATLAB\R2010a/extern/include -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2010a/rtw/c/src/ext_mode/common -IC:\Users\alex\dsPIC_33f_Explorer16_dspic\sources -IC:\Users\alex -IC:\Users\alex\Documents\MATLAB\examples -I C:\PROGRA~1\MICROC~1\MPLABC~1\include dsPIC_33f_Explorer16_main.c
In file included from c:/program files/microchip/mplab c30/bin/bin/../../support/peripheral_24F/timer.h:35,
from dsPIC_33f_Explorer16_private.h:33,
c:/program files/microchip/mplab c30/bin/bin/../../support/peripheral_24F/GenericTypeDefs.h:53: error: syntax error before '(' token
Posted: Sun Feb 12, 2012 9:51 am
TCP/Ip not found does not create an error. just a warning, not important.
Your error is there :
typically, there are problems with boolean declaration.
I thought the blocket handled this now. if not, you might just edit this .h file and check. commenting few lines usually resolve the problem.
(there are few indication on this website/forum on that...)
Posted: Sun Feb 12, 2012 10:56 pm
by jekson
thanks for your prompt reply, do not take into account the tcpip error, and if I generated the code in mplab, but when compiling I get another problem.
[tercer_fuzzy_dspic\sources\tercer_fuzzy.c: In function 'tercer_fuzzy_step':
tercer_fuzzy_dspic\sources\tercer_fuzzy.c:121: internal compiler error: in expand_one_stack_var_at, at cfgexpand.c:515
Please submit a full bug report,
with preprocessed source if appropriate.]
Posted: Mon Feb 13, 2012 12:13 am
that error should go to Microchip's compiler's team. I might help to reach them if you want.
Anyway, my feeling is that fuzzy logic is not a great for embedded system. It typically required too much memory or to evluate complex math functions...
Posted: Mon Feb 13, 2012 2:43 am
by jekson
I can help correct this problem, which I do, I need to finish this project.
Thank you.
