I am making a sampling using the OC(HW) and ADC.
In the dialog of OC(HW), we can set the period for the PWM output.
However, I am not clear about setting the duty cycle.
Could you explain exactly what the set and reset mean in the block?
Thanks in advance.
Quan
Duty cycle of OC(HW)
Re: Duty cycle of OC(HW)
Could you please have a look on the block's page : http://www.kerhuel.eu/wiki/Block/Output_Compare_HW
Unfortunatly, I will not have time to draw something (that would make it clearer)
If there are unclear point, please let me know.
Sorry for bothering you again.
I have read the block page many times, still I cannot get what I want.
Attached is a graph got from the example of Hyper Sampling.
Could you explain how the duty cycle is decided and why there is a "+" between the set and reset inputs?
Thanks very much.
Quan
Thanks very much.
Quan
- HyperSampling.PNG (7.91 KiB) Viewed 10001 times
Hi Quan,
I respond quicky, sorry if there are imprecision.
OC works with a counter. For a given periode (set within the block) the counter will count from 0 to a number, let say it is 1000 here, this number is given in OCmax (it depends on your quartz).
- The ADC starts conversion when the counter is reset, ie, goes from 1000 to 0.
- The OC output is set to 1 when the counter reach the Tset value.
- The OC output is set to 0 when the counter reach the Treset value.
For example,
- if Tset value 250 and Treset value is 350, you will get a PWM duty cycle of 10% on the OC output. ADC will starts conversion while the OC output is 0
- if Tset value 950 and Treset value is 50, you will also get a PWM duty cycle of 10% on the OC output. ADC will starts conversion while the OC output is 1
Please feel free to add any usefull explanation on the Wiki page about OC(HW)
For example,
Thanks for your patient explanation.
I will add some detailed explanation for OC(HW).
Quan
Quan
Users browsing this forum: No registered users and 146 guests
