I create a model that use Fuzzy Logic Controller block, and when I try build show this error:
Error building Real-Time Workshop target for block diagram 'fuzzy_stepmotor_casa'. MATLAB error message:
Error(s) encountered while building model "fuzzy_stepmotor_casa".
I attach the model, the FIS file and the error for help in analisys.
I need a help urgently, Thanks.
Alan
Error building dsPIC30F3012 with Fuzzy
- lente_act3.fis.mdl
- FIS file (Delete the extension mdl)
- (924 Bytes) Downloaded 771 times
- fuzzy_stepmotor_casa.mdl
- Model
- (45.81 KiB) Downloaded 820 times
Re: Error building dsPIC30F3012 with Fuzzy
Hi again,
I found the problem, my model use the 3036 bytes of data memory and the dspic 30f3012 has only 2048 bytes.
Now I wanna know if the EEPROM memory(1024 bytes) can be used like RAM, to data memory, and how I use it?
Alan
Alan
Hi Alan,
It is not possible to replace RAM by EEPROM.
however, you may try to activate simulink optimization, try to check the box "inline parameters". This may save a lot of RAM memory.
