Error in Compiling Model from demo
chad
Post by chad » Wed Jul 22, 2009 5:18 am
I am trying to compile my first model from your demo http://www.kerhuel.eu/wiki/Animation_Co ... irst_model and keep getting the error:
Error building Real-Time Workshop target for block diagram 'chad'. MATLAB error message:
Error(s) encountered while building model "chad".
### Starting Real-Time Workshop build procedure for model: chad
### Generating code into build directory: C:\Users\Chad\Documents\MATLAB\chad_dspic\sources
PNumber of I/O PINs used : 1
TT### Invoking Target Language Compiler on chad.rtw
	tlc
	-r
	C:\Users\Chad\Documents\MATLAB\chad_dspic\sources\chad.rtw
	C:\Users\Chad\Desktop\install_dsPIC_R2007b\dspic\dspic.tlc
	-OC:\Users\Chad\Documents\MATLAB\chad_dspic\sources
	-IC:\Users\Chad\Desktop\install_dsPIC_R2007b\dspic
	-IC:\Users\Chad\Desktop\install_dsPIC_R2007b\blocks
	-IC:\Users\Chad\Documents\MATLAB\chad_dspic\sources\tlc
	-aEnforceIntegerDowncast=1
	-aFoldNonRolledExpr=1
	-aInlineInvariantSignals=0
	-aInlineParameters=0
	-aLocalBlockOutputs=1
	-aRollThreshold=5
	-aInitFltsAndDblsToZero=1
	-aGenerateReport=0
	-aGenCodeOnly=0
	-aRTWVerbose=1
	-aIncludeHyperlinkInReport=0
	-aLaunchReport=0
	-aGenerateTraceInfo=0
	-aForceParamTrailComments=0
	-aGenerateComments=1
	-aIncHierarchyInIds=0
	-aMaxRTWIdLen=31
	-aShowEliminatedStatements=0
	-aIncDataTypeInIds=0
	-aInsertBlockDesc=0
	-aSimulinkBlockComments=1
	-aInlinedPrmAccess="Literals"
	-aIsPILTarget=0
	-aIncludeMdlTerminateFcn=0
	-aCombineOutputUpdateFcns=1
	-aSuppressErrorStatus=1
	-aERTCustomFileBanners=1
	-aLogVarNameModifier="rt_"
	-aGenerateFullHeader=1
	-aGenerateSampleERTMain=0
	-aMatFileLogging=0
	-aMultiInstanceERTCode=0
	-aPurelyIntegerCode=0
	-aPortableWordSizes=0
	-aGenerateErtSFunction=0
	-aGenerateASAP2=0
	-aExtMode=0
	-aExtModeStaticAlloc=0
	-aExtModeTransport=0
	-aExtModeTesting=0
	-aTargetOS="BareBoardExample"
	-aRateGroupingCode=1
	-aRTWCAPISignals=0
	-aRTWCAPIParams=0
	-aRootIOStructures=0
	-aOPTIM_GCC="-mcpu=24fJ128GA010 -O3 -fschedule-insns -fschedule-insns2"
	-aLDPICTYPE="-T C:\PROGRA~1\MICROC~1\MPLABC~2\support\PIC24F\gld\p24fJ128GA010.gld"
	-aLDLIBPIC="C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libpic30-coff.a  C:\PROGRA~1\MICROC~1\MPLABC~2\lib\PIC24F\libpPIC24Fxxx-coff.a C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libc-coff.a C:\PROGRA~1\MICROC~1\MPLABC~2\lib\libm-coff.a"
	-aPIC_REF="24fJ128GA010"
	-aGCCPATH=""
	-p10000
### Writing header file chad_types.h
### Writing header file chad.h
### Writing source file chad.c
### Writing header file chad_private.h
### Writing source file chad_data.c
### Writing source file chad_main.c
Embedded Coder for dsPIC V0.99g(08-Jul-2009) for Matlab R2007b.
Licence Accorded to  Demonstration Version
                     RTWdsPIC@kerhuel.eu
                     Author : Lubin KERHUEL
                     WEBSITE : http://www.kerhuel.eu
                     SIRENE : 503 920 456
                     SIRET : 503 920 456 00012
 Facturation to :
                     Montee du chateau
                     Rue de l arene
                     13260 Cassis
                     FRANCE
### Processing Template Makefile: C:\Users\Chad\Desktop\install_dsPIC_R2007b\dspic\dspic_pic30_gcc.tmf
### chad.mk which is generated from C:\Users\Chad\Desktop\install_dsPIC_R2007b\dspic\dspic_pic30_gcc.tmf is up to date
### Building chad: .\chad.bat
C:\Users\Chad\Documents\MATLAB\chad_dspic\sources>set MATLAB=C:\Program Files\MATLAB\R2007b
C:\Users\Chad\Documents\MATLAB\chad_dspic\sources>"C:\PROGRA~1\MATLAB\R2007b\bin\win32\gmake" -f chad.mk  GENERATE_REPORT=0 MULTI_INSTANCE_CODE=0 PORTABLE_WORDSIZES=0 GENERATE_ASAP2=0 TMW_EXTMODE_TESTING=0
''pic30-gcc  -c -mcpu=24fJ128GA010 -O3 -fschedule-insns -fschedule-insns2	 -O   -I. -I..\.. -IC:\PROGRA~1\MATLAB\R2007b/simulink/include -IC:\PROGRA~1\MATLAB\R2007b/extern/include -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/ert -IC:\PROGRA~1\MATLAB\R2007b/rtw/c/src/ext_mode/common -IC:\Users\Chad\Documents\MATLAB\chad_dspic\sources -IC:\Users\Chad\Documents\MATLAB -IC:\Users\Chad\Desktop -IC:\PROGRA~1\MATLAB\R2007b\rtw\c\libsrc   -I C:\PROGRA~1\MICROC~1\MPLABC~2\include    chad_data.c
In file included from c:/program files/microchip/mplab c30/bin/bin/../../support/peripheral_24F/timer.h:35,
                 from chad_private.h:47,
                 from chad_data.c:28:
c:/program files/microchip/mplab c30/bin/bin/../../support/peripheral_24F/GenericTypeDefs.h:53: error: syntax error before '(' token
gmake: *** [chad_data.o] Error 255
### Real-Time Workshop build procedure for model: 'chad' aborted due to an error.
I checked I am using the latest version C30 v3.12. I am using MATLAB 2007b. Why can't it compile without error?
Chad
Re: Error in Compiling Model from demo
Post by LubinKerhuel » Wed Jul 22, 2009 8:27 am
Hello Chad,
Does the models in the example folder compile ?
Could you upload the model you tried to compile ? (it seems it is not an example)
chad
Post by chad » Sat Jul 25, 2009 3:26 am
Curiously, dsPIC_33f_Explorer16.mdl gave pathing error because it was looking for a Matlab > R2009a folder, while I have R2007b. I got it working by creating a R2009a folder and copying and pasting folders from the R2007b folder into it.
The chad.mdl I made from the tutorial still wont compile though, so I uploaded it here. The Matlab messages might mean a syntax error in a header file.
chad.mdl
the model I build from tutorial
(23.63 KiB) Downloaded 843 times
Post by LubinKerhuel » Sun Jul 26, 2009 6:38 pm
Hi Chad,
This model compiles just fine with matlab 2007b.
I attached the obtained .hex file.
Anyway, if you have path error, you may add the yellow block "Configure Model for dsPIC" in the Simulink Configuration subblocks of the dsPIC blockset and click on it. This block check and configure if necessary the differents paths.
chad.hex
(13.7 KiB) Downloaded 792 times
Users browsing this forum: No registered users and 8 guests
