Greetings,
I came accross an error . Here is the error:
IC:\PROGRA~1\MATLAB\R2011a/rtw/c/src/ext_mode/common -IC:\DSPICT~1\FLASH_~1\flash_led_dspic\sources -IC:\DSPICT~1\FLASH_~1 -I C:\PROGRA~1\MICROC~1\MPLABC~1\include flash_led_data.c, ...) failed.
make (e=2): Sistem belirtilen dosyayı bulamıyor.
gmake: *** [flash_led_data.o] Error 2
### Build procedure for model: 'flash_led' aborted due to an error.
The sentence underlined red is mean : system can not find the file. Its in Turkish. what will be the problem.
Thank you.
error: make (e=2)
Re: error: make (e=2)
matlab version : 2011a and mplab version is c30 v3.25 and the microcontroller is : dspic 30f2010
Users browsing this forum: No registered users and 14 guests
