I was having some troubles with my own model, so I decided to revert back to the dsPIC_33f_Explorer16.mdl that you provide to make sure everything on my explorer 16 board was still working well.
The model compiled fine, but I got strange output when adjusting the potentiometer - it seems like the two filtered values are not being converted to the right type or something.
I reverted back to 3.4 of the blockset (instead of 3.4b), but the same thing happened. I'm pretty sure it was okay on v3.3, but I don't have that version so I can't verify.
Are you seeing this on your side?
Justin
explorer16 demo still working?
Re: explorer16 demo still working?
Confirmed: the two filter outputs need to be set to uint16...then everything works!
-Justin
-Justin
Thanks for the problem report.
I corrected the example and next blockset version will be Ok (thus, above 3.4b).
Don't know what's happend as I did not modify anything also !
Nice curve
Nice curve
Users browsing this forum: No registered users and 18 guests
